hydraulic cylinder repair
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic cylinder repair
    Posted: 15 May 2018 at 8:51pm
Anyone know how to take apart the marker cylinders on a 333 planter? Just pulled it off but haven't tried taking it apart yet. Looks like the bottom fitting comes off then bottom spins off? Is this correct? Thinking I have an internal leak as it always works its way down when it should be up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 12:15pm
Anyone? It has me stumped
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 12:22pm
Remove rod end fitting. Drive the end slug down into the barrel maybe 3/8" inch. Dig out wire snap ring and pull it apart. I ain't there looking at it, but that's the kind I think it is.  You realize you'll be dead in the water if you can't find a seal kit today, right  ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 12:47pm
Here's pictures of what I have. Already have the seal kit for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 1:38pm
Opposite end of what I thought. Remove fitting. Drive the slug in. Remove the snap ring. Pull it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2018 at 9:54pm
Got it,thanks.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2018 at 10:20pm
Don't let the lack of a kit slow you down. Part of my real job is hydraulic seals and repairs. If a seal can't be measured and matched up it's not too hard to get one made.
If you ever get in a bind let me know, I'd be glad to help.
This page was generated in 0.043 seconds.
