Tips for getting front hub caps off the Model G?
sawjinc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sawjinc Quote  Post ReplyReply Direct Link To This Post Topic: Tips for getting front hub caps off the Model G?
    Posted: 13 May 2018 at 4:36pm
Hey all, I have a rusty Model G that I am restoring and I am struggling to get the hub caps off the front wheels. Any tips?
Thanks in advance!
Gerald J. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote sawjinc Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 6:34pm
Thanks for those! Both just state "remove the hub cap" - so helpful! Obviously if rust wasn't involved this task would be a non-event.
The caps have a little lip on the top edge...thinking I may be able to fashion a puller to get them off...
Edited by sawjinc - 13 May 2018 at 6:35pm
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 8:06pm
Steve, often you can just wrap them with a shop rag and grab them with a pair of adjustable channel locks and wiggle them loose, I have an old pair of blacksmiths end nippers much like these that I use for these and for trailer hubcaps that won't come off the hub
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 8:07pm
Using a hammer you can "tap" the cap between the ridge and the end toward the center of the cap moving around the cap- not all tapping at one location.   tapping...not beating as this is a press fit -HTH
Edited by JoeO(CMO) - 13 May 2018 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote sawjinc Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 9:03pm
Thank you!! Channel locks and a rag did the trick!
truckerfarmer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 9:55pm
Dad taught us to use a small cold chisel between the lip and the hub. Have to be careful to not punch a hole in the cap. 12 oz ball peen hammer and light tapping is all it takes.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 3:27pm
truckerfarmer that the way I always removed mine.
