TL14 help
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Topic: TL14 help
    Posted: 11 May 2018 at 11:01pm
I'm looking at a TL14. Can anyone tell me anything about the torque converter setup that uses some sort of tire?   Owner says the tire is shot, is that something that is available or am I not going to find anything to replace it? I'm not going to buy it if I can't get parts. Thanks for any help!
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 11:49pm
The late TL12's had a shuttle type trans, it had a tire in a container bolted to the fly wheel the hub had the U/J connected to the trans. On my TL12 we sometimes sheared the valve stem and had to remove the tire assembly to replace the tube, by memory I think we used to jack the motor up abit to get clearance to remove it, it was about the size of a wheelbarrow tire. the late TL14 did not have this setup it had a torque convertor transmission similar to the later articulated loaders
