Allis Chalmers 230 combine engine starter question
Preston230 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 230 combine engine starter question
    Posted: 08 May 2018 at 8:40pm
Ok guys so i have a 230 gas Gleaner combine engine and I'm going to be putting it in a Wd45 to make it look like a diesel. I have heard that you will need a D19 starter. I was wondering why you cant use the 230 starter just in the right place in the bell housing of the transmission. If you guys could help, that would be great.
            Thanks
                 Preston
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 9:03pm
You will need a WD45D flywheel and adapter plate and use your starter + ALOT OF OTHER SMALL IDEMS.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 9:11pm
Ok thanks for the information MACK. So i can use my starter and yeah i have the flywheel and adaptor plate
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 9:52pm
I thought this was a GAS WD-45 chassis ?? ...which means your gas flywheel is wrong, the gas radiator is wrong, the engine backplate is missing, the left side frame will need to be modified, the hood is too short, you have no throttle linkage or governor, etc, etc.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 5:29am
Yes this is a gas chassis. I have most of the parts like the flywheel, starter, adaptor plate, hood, and i have moved the outlet on the wd45 gas radiator, ect.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 8:36am
Is the clutch shaft the same on gas and diesel tractors?
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 11:40am
What makes a gas engine look like a diesel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 1:56pm
I think the clutch is the same. The gas is a six cylinder like the diesel so that what makes it looks like a diesel
