SC blade extensions
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: SC blade extensions
    Posted: 29 Apr 2018 at 11:10pm
Built 6" extensions for my 6 blade. Originally had planned on going 8', but realized I couldn't angle it all the way without it hitting the tires.
Not a perfect match, but, good enough for my use. So far I have $60 invested in the extensions.
Still have a few more bolts to replace, as every one on the back half was loose.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 7:04am
That looks really good to me.
Does a cutting edge bolt to the bottom?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 7:39am
Good work! Let us know how they work. I would like to extend one of mine some day, 6' is a little narrow and 9' is a little much. Have thought about cutting an original in two, however the value of these things calms that urge.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 1:05pm
I have a SC blade modified to 3pt the PO added about a foot to each extension the blade is about
11ft wide
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 3:56pm
Yea, I bought the regular / original extensions for mine and as you say the blade hits the tires ... however that much angle is enough to do what i need to do... can't "turn it complete" to push backwards but I don't do that anyway
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 7:57pm
Wow! Very nice!! You could get a second job making those!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 9:47pm
Got it finished up today. Bladed the driveway and leveled the dirt over the drain field that was dug in last fall.
7' cutting edge for a road grader bolts right on. Put a used one on for now. Gotta get a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 10:00pm
By the way. Changing the cutting edge is an adventure. When you pull the bolts, EVERYTHING comes apart. I'm used to changing road grader edges. With 2 guys, we could change them in 5 minutes. Doing this on took me close to an hour. But the I wasn't on the time clock either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 10:16am
That looks great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 9:55pm
Thanks. Lot of welding and grinding to get the shape right, but I enjoy metal fabrication.
BMinor0788 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMinor0788 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 9:02pm
Are you interested in making anymore extensions? I’d like a 7’ blade behind my WD-45 also. Can you turn the blade backwards with them on?
Brandon
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 9:54pm
Not interested in in making any more. Sorry.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 6:16am
Brandon
We used to have a blade with extensions. The only way to turn it completely around (to push) was to manually turn it before it was mounted (hits the tires) on the tractor.
Post Options Post Options   Thanks (1) Thanks(1)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 7:00am
For those of you that are wondering about making them. All I did was trace the end of the blade. Took it to local metal supply place. They cut and bent the main blade curve. The bottom bends where the cutting edge attaches are 2 pieces of flat steel welded together. Just trial and error. Tack it together then match it to the profile of the blade. Once I got the profile to match, just started filling with weld and ground it to match.
