One-Sixty Exhaust Manifold Question
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Topic: One-Sixty Exhaust Manifold Question
    Posted: 24 Apr 2018 at 8:20am
I'm looking for a replacement exhaust manifold for my one-sixty (Perkins AD3.152 engine).  I'm going with a vertical exhaust.  All of the manifolds I see on-line are for Massey Ferguson tractors.  Anybody have experience with particular parts for this?  Any suggestions would be appreciated.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 12:31pm
look on agco parts books online nad get the part number for the one on the 160, and get the part number for one on a massey that used the 152, and see if those numbers cross to the same part number.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 4:56pm
Thanks for the help.  I poked around both parts books and this is what I found:
Part number from the One-Sixty is 72080342.  The part number for Massey Ferguson appears to be 736298M1.
Is there somewhere I need to look to determine if these two part numbers are equivalent?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 6:34pm
just a google search may find someone who crosses them. A quick call to an agco dealer may see if they cross to a new common number.
Edited by injpumpEd - 24 Apr 2018 at 6:36pm
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 8:05am
best I can remember from my 160s the early models had a 2 bolt flange and the later ones had a 3 bolt which is the same pattern as the MF 135 HOWEVER the 160 had a side discharge and a top discharge opening for the exhaust piece that the muffler bolts to and the 135 manifold exits the BOTTOM... :-(   Someone here ask if the manifold could be flipped... don't know ...
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 9:45am
I looked around net, have not found the exact exhaust manifold.
The 160 hood flips up, so the exhaust elbow gets the muffler out and away from the hood.
From the Massey Ferguson world, it looks like the manifold from the 250 or 20C diesel tractor may work. Cheap and I think the cast iron elbows are also available.  However, the muffler would be relocated fwd some.
I think Perkins has dropped support of this engine, at least from my serial number, they said too old, don't know nothing about it.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 9:53am
I think the only way I'm going to find out for sure is to pull the trigger on the one that looks like it will work and see if it actually does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 10:26am
The older two bolt manifold looks just like the manifold for the MF 2244 Crawler, p/n 977595M1.
We need to find the Perkins Guru. I am sure they had a wide variety of exhaust manifolds
available. Also intake manifolds , oil filter bases, and water pumps. But where is the expert?
wigtrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wigtrain Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 4:21pm
Just  did this on my 160 a year ago. I replaced the manifold with a side discharge manifold from a Massey. Then flipped it over so that the elbow ( purchased separately ) would point up. I didn't want to cut my hood so I made a flat plat that was 1 inch thick to space the elbow out. All works fine. If you need I'll try to take some pictures this weekend.  Here is where I got the parts
http://www.yesterdaystractors.com/cgi-bin/store/model_parts.cgi?SearchArea=Massey-Ferguson&md=135&cat=Exhaust%20System (Part No: 740221M1)
and then (Part No: 1693855M1)
As I said this set up will be too short to clear your hood so space out the second part to create whatever clearance you want. I had to flip the first part to have the three bolt flange the allow the elbow to point up. I made my spacer from aluminum. The whole thing works fine and looks good too.
Jim Wiggin
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 6:26am
Thanks for the info.  I'm looking at the parts.  Pictures would be greatly appreciated.
