Electrolysis Advice Needed
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: Electrolysis Advice Needed
    Posted: 12 Apr 2018 at 10:37am
I've been cooking out a very rusty engine block for over two weeks. It's still removing a significant amount of rust and corrosion  We are leaving home for two weeks. Should I remove it from the electrolysis unit, wash it down and spray it with light oil or, leave it in the tub unplugged from the power source until I return?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 10:38am
I'd unplug the power supply, leave block in tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 10:43am
Well I haven't left it that long But I would go with the light oil option. Maybe better yet would be to just let it run while your gone? Especially if you have more clean time needed.
Maybe have some one check on it daily?
I would be afraid it might rust some in the tub. But getting no air (submerged) maybe it would be OK?
 Are you getting it turned occasionally so that the line of site process is getting some of the internal areas?
This page was generated in 0.504 seconds.
