Allis Chalmers 6040 Info
schnor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schnor Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 6040 Info
    Posted: 12 Apr 2018 at 10:24am
Have Hydrulic pump issue, does anyone know where I can buy a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote schnor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 4:50pm
Near as I can tell the pump might have also been used on a Renault 551s tractor. Is there anyone that can confirm that??
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 7:06pm
The 6040 is made by Renault, but do not know the model number.  The only thing Allis on it is the sheet metal - nothing mechanical.  I can't help much more than that.  Have you replaced the fluid, filters and screens related to the hydraulics?  That is a good place to start.  Don't assume it's the pump - might not be.  A local hydraulic repair shop might be able to help you out.
Rooster 🐔 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rooster 🐔 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 9:44am
Don't know if you found a pump or not. I have a 6040 Allis Chalmers found pump that fit mine. Here's the number. A7700035327 bought on AMAZON.$960.00.They have it on eBay little cheaper but no returns. Mine works fine . Tried finding one with pump number no luck The number I gave you is a reference number. It fits several different tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 8:44pm
Try Surplus Center in Lincoln, NE.               MACK
