V8 in wd45 or d17 ideas....????
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Topic: V8 in wd45 or d17 ideas....????
    Posted: 12 Apr 2018 at 8:16am
Hello guys I am thinking of a project tractor for going on tractor drives and for a unique show piece. Do you guys have any ideas or has anyone done this? I would be interested in purchasing something with the v8 in it already also. Any photos? Really I am just trying to make up my mind on a few things! Thank you much!
Andy Gubbels
Andrew Gubbels
Gubbels Restoration
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 8:51am
Have a friend in Illinois City, Ill, Don Emmons,  who has done this a couple times. Give him a call 563 260-1211
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 10:51am
I've seen some.  A small block Chevy with a lumpy cam would be cool. For something really unique, I saw a G at the GOTO in 2001 with raised front frame and a front mounted small block Chevy. Same guy had a Chevy powered B. He said that he used to build race cars. Then there was the G with duals a mower deck and a V-8 Olds in the rear at Portland GOTO. You are only limited by imagination.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 4:43pm
i want to put a straight 8 hudson in a unstyled  thats what i have been thinking about
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 4:46pm
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 6:35am
There are Funk Flathead Ford conversions. I've seen homemade Farm All H and M, Allis Chalmers WC, WD, WD45, B, and C's with V8's. Oliver 77 and 88 with V8,s. Small Block Chevys seem to be the most popular. I drove an Avery at a fun tractor pull with a Ford Ranger Pick UP V6 in it. Lots of fun with a very wide RPM range. They are doggy at low RPM because they don't have low RPM Torque like a tractor engine. Make sure you have good brakes because you'll need them. Click on site below for Marvin Baumann's collection of home built conversions.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 6:40am
Now that Str8 8 would be KOOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 6:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 6:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 9:05am
https://www.youtube.com/watch?v=klPJZ_hR0hI
Click on above. Drive it like you stole it!!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 9:09am
How about an 8V92 in a D17.  Sure wouldn't want to try and pull anything with it, but it would sound good on a cold morning!  Wink
Still in use:
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 9:13am
there is a older man about 20 miles from me that has a hemi with headers in his WC he said its to load to drive
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 9:55am
triple nickle or a 3208 cat or maybe a 6.9 ,7.3 ih  in the d17
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 2:25pm
My uncle Carl who lived near Buckhorn, MO put an automotive V-8 in a farm tractor a bit larger than a WD45 about 1952. He used the tractor mostly to run a saw with the PTO. He had problems with the engine overheating. At the time I (at age 10) figured the problem was that the car manufacturer depended on air flow from driving down the road at 30 mph or greater cooling the engine block directly and so didn't use as big a water pump (or pair of water pumps). Could very well be that the tractor radiator wasn't capable of holding down the coolant temperature because of fewer fins and tubes than the automobile's original radiator. Might be that building a custom water pump with twice the volume capacity would have solved that problem or working the car radiator into the tractor in place of the tractor radiator.
Gerald J.
garr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garr Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 7:38pm
Saw a WC the last time Allis Chalmers were at Gray with Chev V-8 & disc brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 10:19pm
Saw a 45 diesel chassis with a v12 Seagrave engine in it .Did a decent job.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2018 at 11:53pm
I seem to remember that Shameless has a V8 Allis, maybe you could make a package deal for it and the pretty machine.   Andrew, you could have an old fashioned car smash, you know, 3 hits with a sledge for $5.  (on the pretty machine, of course!)
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 6:12am
OK, tossing a V8 into a tractor is 'old hat', 'easy peezy', 'boring'.......
Now if you want a UNIQUE ride, toss TWO small diesels,coupled inline into your project. Them 'surplus' VW ones come to mind.
Dependng on room and tractor ,you might get 3 engines to fit.
Yeah, another 'project' I'd like to do but too little time,too little space,too little money....
Jay
