Question on a C air cleaner
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Topic: Question on a C air cleaner
    Posted: 08 Apr 2018 at 7:05pm
Whats a good way to replace the mesh in the air cleaner. Or is there a way to clean it out. It is to the point something needs to be done. With the air cleaner hose hooked up engine is choking itself. With it unhooked runs like a top.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 7:10pm
Have you pulled the cup at the bottom and made sure it's clean?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 7:31pm
Yep i think have it narrowed down to the mesh being dirty. And as far as i can remember. It hasn't been clean in my lifetime.
Edited by Krazy Karl - 08 Apr 2018 at 7:35pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 8:18pm
I have set one in the parts washer. Put the hose in the top and just let it run thru. Then I took the cap back off proved it upside down and let it run the other direction. Hot wash it when your done. Mine turned out clean in just a few hours. To take the mesh out you'll have to break the welds. And weld it back together when your done. The old packing is much heavier than what I could find for replacement when we took dads apart. If I were to do another I'd just hot wash with simple green. The full streangth simple green we used for cleaning military equipment is stronger than Walmart gets used with a hot wash it eats the grease right out. It won't hurt the stainless mesh inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 8:23pm
They usually are a real female dog at that point.  When I had one that bad, I used a drill and drilled through the weld spots and took it apart.  I bought new stuff from one of the vendors on here.  THE ONLY WAY to do it....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 8:49pm
Recon one of them sonic cleaners would do it?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 9:39pm
Wait a minute.....to take the mesh out to do routine maintenance you have to break welds?!?!
Looks like Henry Ford's "wanna-be tractors" had another advantage....just use a pointed object to snap off the bottom retainer on the cleaner, and the mesh pulls right out for easy cleaning/replacement.
Hm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 7:21am
Hm.
Had the proper routine mantainence (change the oil in the cup daily, more frequently in dusty conditions) the mesh would never have gotten dirty enough to be a problem.
Now that you have one that’s choked up, the parts washer method works well. Also a good soak in a 5 gallon bucket of kerosene will do the job, just keep plunging it like a stopped up drain.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 7:29am
Put mine in the parts washer for a few days with fluid running through it.  Worked for me.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
peterh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 7:52am
would a result of a clogged/dirty air cleaner be the engine "pulsing" when running? The linkage rod from the governor on my CA goes back and forth and makes a pulsing sound. I confirmed it has good gas flow.
1947 C, 1949 B, 195? CA
60 series cultivator
fertilizer side dresser
2 bottom snap coupler plow
1 bottom plow, Cole planter
Post Options Post Options   Thanks (1) Thanks(1)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 8:06am
My G used to do that, and my B currently does, due to a broken anti-surge spring. You might check out. Fixed it on the G by adding a stiffer spring.
Here's a link to what I mean.
Not saying it couldn't be the air cleaner, but this is something to check as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 11:57am
thank you, Creston. It probably needs to be cleaned anyway, but I know it doesnt have the spring there, so I will get that taken care of too!
Edited by peterh - 09 Apr 2018 at 11:58am
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 12:24pm
pull the mesh out and unroll it wash with water let dry roll back up and reinstall done that on all my oil bath air cleaners on wd and wd45 d-15 alsoworked like a charm
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 6:20pm
How much oil is needed in bottom and type?
cjallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 6:28pm
There is a fill line on the fill cup. For oil, not a thick or viscous oil but a thinner oil. I use plain old synthetic 10w30.
@Hunt4Allis
Edited by cjallis - 09 Apr 2018 at 6:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 6:31pm
I replaced mine with new mesh from Steiner. I installed it by sticking it up into the air cleaner, rolling it. It was a pain in the but to do that but I won't ever half to do it again and it was easier than breaking welds and rewelding!
