Allis Chalmers CA |
Post Reply ![]() |
NCACCA ![]() Bronze Level ![]() Joined: 28 Mar 2018 Location: North Carolina Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Mar 2018 at 3:10am |
Hey guys I'm new and I just got my first tractor and its a CA and I'm trying to get a list of attachments I could get for it and I just cant seem to find it. One member had a list but nome of the photos load so I can't seem to find anything from it.
ac160 ![]() Silver Level ![]() Joined: 02 Dec 2010 Points: 404 |
Welcome to the site. You can find lots of good information here. Some of the attachments include a blade, plow, disc, mounted cultivators, rear cultivators, dirt scoop, rotary hoe, and planter in snap coupler. If you CA is a pin hitch it is harder to find attachments, but it can be converted to snap coupler.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Allis implements are somewhat difficult to come by. If you can't locate those you need, it con ne converted to a 3 point and you can readily find whatever implements you need.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5086 |
Here's a list of the factory built CA implements I have;
#52 2 bottom plow #54 2 bottom spinner plow #20 disc harrow (available in various sizes) #40 disc harrow 2 row drill planter 9 run All-Crop-Drill 2 row row-crop cultivators 5 shank coil spring field cultivator 7 foot spring tooth field cultivator 2 disc plow (Athens built for Allis) 4 disc tiller (Athens built for Allis) curved shank Sub-Soiler 7 foot front mounted Snow Plow Trip Bucket Front end loader Rear bladeDirt scoop #5 sickle bar mower #10 post hole digger with the CA mount Carry-All Things I know of but don't have; #30 disc harrow spring tooth harrow 2 row rotary hoe 1 row cotton picker Maybe some other things as well. So you can see that Allis Chalmers built or sold any implement that you could possibly need, most everything was available for the Pin-Hitch tractors, then later they were also available for the Snap-Coupler equipped tractors. This was in my opinion the best lifting and draft sensing system of any tractor of it's time. Searching for the correct equipment to match to your tractor is part of the fun of a unique tractor of the Allis Chalmers brand. If you have the desire to ruin you tractor with a 3pt why did you not buy a Ford or something else? Edited by PaulB - 29 Mar 2018 at 6:34am |
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Paul B "IS THE MAN WHEN IT COMES TO THE CA ALLIS". Both in the field and on the pulling track.
TMiller/NC ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Welcome, I have a CA with pin hitch, as AC equipment is scarce around here, I have been messing around with making a 3 point adapter. Which end of NC are you? Tim
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87582 |
well, the first thing to know is what type of hitch / hydraulics / arms are on the back now ?
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
TMILLER There is more to making a three point hitch than meets te eye .Made one for my B Works ok with finish mower.If you look at a ford hitch is under axle and third arm is not to high above it.I could not get close to these measurements.With custom built ones hitch is so far behind axle you need a lot of front end weight.Picture of mine on customized B . Hope you have good luck .PS I am in sunshine n c
wfmurray, I'm currently not going to hook to any pto equipment, just working on attaching a 3 point disk. Will post a couple of pics when I am finished. Tim
Hello everyone thank you so much for the replies! I have a 3 point hydro hitch. So I guess it will be easier to get attachments then. By the way my first time ever owning a tractor. So any and all knowledge that I can learn would be great!
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
If you are looking for implements, I have a 7' CA20 pin hitch disc I would sell. If you are interested, pm me.
Post Reply ![]() |
