180 tire size
langleycattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote langleycattle Quote  Post ReplyReply Direct Link To This Post Topic: 180 tire size
    Posted: 25 Mar 2018 at 10:14pm
I just got a 180 and the tires are old, hard and cracked. Mine are 18.4-28 I found some 12.4-28 that are like new and only $250 for the pair. Are they going to be too small? TIA!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 10:22pm
I have some 18.4-28's here that I'll make ya a deal on,, they're older tires on rims,, but I think they're decent solid tires, I can text ya some pic if ya be interested
I think the 12'4's will be way to small, they be more for a WD...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2018 at 10:57pm
Oops...I messed up,, them tires are 26's,, not 28's...still 18.4 tho
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 6:33am
12's will be way too small for a 180. You need the 18.4's. Those were the smallest tires on that tractor form the factory I believe. Some had 30's
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 7:10am
Standard tire for a 180 was an 16.9 X28, but the vast majority were the optional 18.4 x 28's.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 7:30am
12.4x28 are for a ford 9N. way to small for a 180
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 2:51pm
I think he was saying that the tires he is looking at are 18.4 x 26".
One of the only things I disliked about Dad's 180 was that it had 18.4 x 28 tires. Comparable tractors (JD 3020, IH 656, MF 1085, etc.) came with 38" rubber which gave them more ground clearance and more "footprint".
Dad also had a 185 that came with 18.4 x 30 tires. Even the two inches in diameter made a difference.
18.4 x 26 will work, but you are going to give up another inch of ground clearance and less rubber on the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 3:08pm
18.4-34,s really help in tillage work and tractor pulling
Edited by DougG - 26 Mar 2018 at 3:10pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 3:09pm
Actually if its like the 18.4 X 26 tires on my 180 they are as tall or taller than the
18.4 X 28 on my 185 because the side walls are taller.Even tires the same size don't
measure the same brand to brand lots of times.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 4:30pm
Way way waaaaayyy too small!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 4:40pm
