D14 Hydraulic Transport Valve
r8f1k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Topic: D14 Hydraulic Transport Valve
    Posted: 16 Mar 2018 at 8:07am
How do you get 2 way hydraulics on a transport valve system?  I am just looking for a pressure and return.  I know the system will make certain cylinders work slower, don't really care.  Just looking to use my 2 way cylinders with my D14.  I am also looking for an "elegant" way to do it.  Something neat and clean.  Ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 8:24am
Mount your 2-way valve/valves to the left of the seat. Use a hydraulic hose to connect to your existing outlet for the "feed" into the 2-way valve/valves. Your existing steel return line back to sump will have to be teed into for return oil out of the 2-way valves. Now, when you want 2-way hydraulics, you simply plug in the hose. You want 1-way high pressure hydraulics....unplug the hose and use the existing outlet.  For elegance, chrome the control handle on the 2-way valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 8:27am
first thing you need to understand is that the D-14 has 3,500PSI hydraulics so you need HIGH PRESSURE cylinders. If you have them, just add a 3 way spool valve onb top of the roackshaft and plumb it in. The 'parts manual' has drawings of the official parts.pieces and install.
I'm sure others can offer knowledge. I know 'Troy' here has a 3/8" hole int he left side of the 'pump sump' that someone used as the return line to get oil back into the sump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 9:33am
Anyone have any photos?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 10:18am
I put an el in the return hole on the left side of the sump, just in front of the clutch pedal.  I then ran a rubber line to the rear, with a quick disconnect on the end.   I ran a backhoe with it and it did a real nice job.  It didn't seem to be running slow to me.
Edited by john(MI) - 16 Mar 2018 at 10:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 1:02pm
Did you run an "L" or a "T"?  Right now there is an "L" going to the pump, another "L" won't do much.......Can I plug the return port on the transport valve and plumb a quick disconnect right onto that return line?
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 2:50pm
There is a pipe plug on the left side just ahead of the clutch.  That port is for return.  Take that out and put an el in that hole and proceed from there.  I just tie wrapped a rubber hose along the steel pressure line going to the rear.   I guess if you wanted to get fancy, you could try to find some of the steel tube the size of the pressure line and run it back there.  I bet that size of steel line would be a real pain to bend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 4:04pm
He already has an elbow in that port ahead of the clutch pedal because he has a transport valve on it. Remove the elbow for the return at the transport valve (use two wrenches so you don't crush the elbow fitting) and install a tee between the elbow and the transport valve. Use the existing steel line to return your 2-way valve oil. You can make the steel line reconnect after installing the new tee. Use as short of a tee connection as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 8:25am
Got it.  I will get to work!
