I now own a tractor!...Allis Chalmers C
redbirds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Topic: I now own a tractor!...Allis Chalmers C
    Posted: 12 Mar 2018 at 11:05am
I've had my C for about a month or so, and have been working on it with the help of many posts here on "The Forum".  I'll try to get some pictures up and look forward to everyone's input...I think I've found the right place for answers and expertise. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 11:06am
Apologies in advance if the photo is huge, I suppose I'll learn as I go.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 11:51am
That is a very good looking C.  It has the axle of a B but looking at the rear wheels one can see it is for two rows cultivation - wider than a B.  You can be certain for looking at the other side.  You will find a steering connecting rod coming from the steering gear box that is usually longer and goes up.  The B Steering connecting rod goes down
In any event you have what I believe is the best looking tractor Allis Chalmers made.
With my father we were pleased to sell the C for the life of the unit.
You will find this forum to be most friendly.  There is knowledge here for you assistance.  All you have to do is ask.
Welcome!
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 12:12pm
Thanks Bill.  Yes, it is a C with a B front end and tractor number 50XXX.  It looks like that puts it at a late 46 or early 47 if I read the serial number chart correctly. Someone hand painted CA on the sides of radiator, but I assumed safer to look at number on tractor.
It is certainly a work in progress and I look forward to seeing it run.  I saw it online and decided I needed to trade an old dirt bike for it...makes perfect sense since I have ZERO tractor experience.  Nonetheless, I managed to free the very stuck engine, along with all the valves and rusty rockers, and can now turn it with the hand crank.  I found a used manifold, cleaned carb, and am putting it back together.
I've purchased a new alternator, 12v battery, 12vcoil, and 12v solenoid and that is where I'll need help with wiring.  I also have a new volt meter, and key ignition switch with four posts on back.  Until the alternator is on, I'd like to wire for power to the coil in its simplest form, so that I can see if it will start by hand.  I can then add lights and alternator if I can just do basics to fire it up first.  Any thoughts on this plan?
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 12:39pm
congratulations...a tractor can do more than a dirt bike, well, different things...
you have come to the right place for someone to verify your plan, may take a few minutes, or hours...
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 1:17pm
Thanks for the welcome, FloydKS.  I think I've just really wanted to prove that things could be fixed despite the outward appearance and my lack of experience.  I'll throw out the first real operation question.  Does my starter need to actually have a switch mounted on it to work, or can power be supplied directly to the post on the bottom via solenoid and large wire?  Picture should show "post" I describe on the bottom.
Edited by redbirds - 12 Mar 2018 at 1:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 1:21pm
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 1:47pm
Rodney Thompson aka Rod (NH) has all this info for you at   http://rodnh.byethost12.com/?i=1. I've found everyone here very helpful for my B work.
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 2:00pm
Hi redbirds, welcome aboard.  You've come to the right place for anything AC, and many things not AC.  You will find a wealth of knowledge here, both orange, and not.  You will also find that the guys LOVE pictures.  Nice looking tractor.  I see you are already working on it.  You will fit right in here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 2:15pm
Thanks for the input already. I’d just like to hear it run then see where to take it from there. Here’s a pic of some of the back. Stock? Homemade?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 2:46pm
The shop manual I have on line can help with lots of the details.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 3:03pm
Congratulations on the Allis!
Lots of good folks and information here!
ErikR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ErikR Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 3:10pm
Congratulations and Welcome!!!!!
1950 B
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 5:46pm
Nice C!  Love the front tires.  Welcome to THE forum.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:30pm
WELCOME!!!  You've got a gem there and you will love it as much as I love my C.
I can't see well enough to help you on your starter issue.  You'll have to post a better pic.  That starter doesn't look at all like mine on my C.  Do a search and you will find a LOT of info on these starters and their problems.
GOOD LUCK!!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:41pm
Redbird
There's a Gathering Of The Orange, GOTO, In Gray, TN. in April this year. You must not be very far from there.
There are 2 GOTO's each year, that are hosted each year, by different clubs.
Dusty
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:45pm
Good tractor for your first one, easy to work on and sounds like you are well on your way if you had to free it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 7:17pm
Yes, I fiddled with all the prescribed ingredients to free the pistons. I settled on sliding a fine feeler gauge along the top edge of each piston and letting pb blaster and transmission fluid seep in. Had to shape a new key for the crankshaft pulley and just put very slight pressure with a bar as I noticed the fluid was making its way down. Eventually that and some persuasion with a wood block got it moving. I was patient with it and now it moves well. Need to get to the point I know I have a spark and work on a hand start. It turns well enough I believe it is possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 7:40pm
redbird--- the ORIGINAL starters had a contact switch mounted to the starter. You pushed a rod inward and it made the contacts touch and the hot wire from the battery was then energized to the starter motor.
your motor seems to have the contact switch removed and a POST added in its place.. So YES, you should be able to use a remote solenoid with a wire to the starter.. Then a button or key switch to energize the solenoid... just like a car or riding lawn mower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 7:59pm
Great, Steve. Thanks for looking and commenting. That is how I think I’d like for it to operate, if possible. I found a diagram for wiring and will lay it out to see if I’m on track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 8:07pm
New 12v solenoid for this process.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 8:13pm
Welcome to the Orange Asylum, Redbirds!  Dave here.
You've stepped into the tractor world basically same way as I did many years ago, bringing home a very stuck '48 B that looks strangely more like your C than a B.  I broke mine free too... it had a magneto, rather than distributor, and it started up for me for my first time on a cold, damp night when SHE didn't know it was out in the shed... raining dirt, rust, embers and oil out of the exhaust on the first snorts.  WEAR A HAT!!! LOL
The ignition system is incredibly basic.  Power flows from battery to coil, then from coil to distributor.... through contact points, to ground.  When the points open, magnetic field in the coil collapses, and you get a spark out the coil tower.  That spark flows through coil wire to center of distributor, and hopefully, the rotor is pointed to the wire going the the correct spark plug, and hopefully, the point timing and dwell are approximately appropriate, and there's a little fuel, air, and compression in the accordant cylinder to pop it off in the RIGHT DIRECTION.
Lap the valves and check the springs before you put the head back on, so 'ya don't hafta do it again later.  It'll run.  Even if there's a big gap between pistons and liners, and the rings are missing, it'll still run.  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 8:26pm
If you want electrical help contact SteveNJ.  He is a sponsor on this site and our "in house" electrical expert.  He will have what you need or can rebuild what you have.
Also, check the sponsors on this site.  SteveNJ is one.  They all can be of help.
Take good care of my favorite's (the B) brother the C.
Let us know how it goes.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote redbirds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 9:01pm
That’s encouraging Dave! I’ve already had the head back on for a bit and have done a bit of valve adjustment. You are correct in that these things seem to be amazingly resilient. When I popped the valve cover off, the rust was crazy. After Scrubbing, brushing, spraying, etc, now the springs move up and down in time with the rockers and it’s really sort of hard to believe. Pure labor and patience leads me to believe there are lots of things, previously abandoned, that can be fixed. I want to see the results of working and trusting that it will free up. I’ll compliment quality equipment too, in that nothing so far has been a shock other than owner neglect. The parts are what the manuals describe and what you see is what you get. It’s a fun challenge and a learning experience.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 9:39am
Better get on the ball , GOTO in Gray in 43 days 21 hrs and14 minutes give or take a few. Scott
This page was generated in 0.131 seconds.
