Bosch Injectors
740Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 740Miller Quote  Post ReplyReply Direct Link To This Post Topic: Bosch Injectors
    Posted: 07 Mar 2018 at 5:16pm
how do you identifly which Bosh injectors you have. I've looked up the numbers on the injectors and i'm unable to find a link.
Thanks
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:50pm
I think that the Allis injectors have the return line on the top and the Bosch on the side
Bradleytrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:59pm
Can you post a picture??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 8:57pm
AC used two different Bosh injectors. They are stamped on body as to which they are.      MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 7:01am
Most of the "Bosch" injectors, are actually American Bosch, or AMBAC injectors. There are some German Bosch injectors out there for AC, but the majority of those I've seen are out of 6070/Late 6080's. I've often wondered if there was a serial number break, but parts doesn't indicate that. The AMBAC injectors will all have the same type number on them, but will have a letter stamped up toward the top indicating which nozzle is installed. That only applied to when they were new, many are rebuilt without regard to matching that letter code to the nozzle tip. What are you looking for? More info helps.
