Will a D17 SIV run a hydraulic motor |
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Topic: Will a D17 SIV run a hydraulic motorPosted: 02 Mar 2018 at 10:10pm |
Just wondering if it has good enough hydraulics to run a motor that runs a conveyor on a hay grinder/feeder cart? It is one of these chop as you feed rigs.
ALLIS EXPRESS!
This year: |
DougS
Posted: 03 Mar 2018 at 5:34am |
Do the specs say how many GPM are needed?
DrAllis
Posted: 03 Mar 2018 at 6:39am |
Your pressures are probably OK at 2,200 psi. If the gallons are too low, it will just run slow. Extended use would heat the hyd oil, but I doubt this would be extended use ??
