Hydraulic Oil Question
MikeinArk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinArk Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Oil Question
    Posted: 06 Jul 2010 at 9:49am
Have early 1957 D17 What hydraulic oil is best for the system? Standard tractor hydraulic oil?
1957 D17,1973 Mustang Mach I CJ, 1984 Mustang anniversary Conv, 1966 Thunderbird, 1978 Mustang Ghia, 1974 Ford F100 Ranger
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 10:58am
Haave been using universal trans-hyd fluid in my D14/15/17 for several yrs with no problems.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 11:02am
I get hyd.fluid from TSC,meets all manuf.specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinArk Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 11:22am
Thanks
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 3:48pm
When we sold them it was SAE 20 NON DETERGENT oil. Worked well.  However, I have heard very good reports of the trans-hyd fluid.  I am now a convert.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinArk Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 9:25pm
I guess I will need some good luck. Topped off the fluid lift arms won't move. With tractor running has a noise coming from pump area. It is either the pump or the ram cylinder or both. Trying to figure out what to check first.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 10:24pm
Check the oil level again.
If the hose which runs through the rear end is broken, it will fill your transmission with hydraulic oil.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 10:40pm
If you end up having to replace the hose, buy the hose from AGCO.  There is a stripe on the side of the hose.  When installing the hose, DO NOT allow any twist to the stripe.
You tractor has a high pressure low volume hydraulic system.  The everyday run of the mill hydraulic hoses are not strong enough to handle the pressure.
While you have the rockshaft housing removed, it is a good time to replace the lift cylinder O-ring and the two back up rings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinArk Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 8:39pm
Thanks Clay
I will have to check it out this weekend
