CA spark plugs
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Topic: CA spark plugs
    Posted: 26 Feb 2018 at 8:51pm
I noticed that A295 plugs do not make it to the chamber on the CA. Looks like it needs another 3/8" to make it. What would be a good alternative for medium heat range, non resistor? I'm just taking a guess that the 45 could be the same way?
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 9:04pm
Get in touch with SteveNJ.  He is our resident expert on electrical.
I can tell you when we sold them new we used AC45 - AC48 depending on the engine condition.  They worked fine but that was then.  Now I understand the AC plugs are not so good.  Lot of people on this site like Auto Light.
Hey, if you are from Hanover PA and you are unaware, there are some great Allis People near you.  Fred Wilke for one.  He has an outstanding collection of Allis and John Deere.
We just had an Mid Atlantic Allis Chalmers Club meeting there.
Take good care of that CA.  Neat tractor.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 9:27pm
Do you by any chance remember how long the original AC-45's were? I was wondering if plugs ever changed length during any rationalizing of part numbers over time? I also looked at some 3/4" reach as well, they are about 1-2 threads too long ( threads exposed in chamber could cause a problem removing down the road).   I have met a few AC guys local, all been great people with a lot of knowledge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 9:29pm
Why do you think the plug should be deeper into the combustion chamber? Just curious...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 9:32pm
The 295 plugs fit in the B and C heads........ why don't they work in a CA ?
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 9:49pm
ca calls for 295 or 303 "3/8" reach plug in auto light.depends on if you want resistor or non resistor plug.the 295 non resistor is a little hotter plug according to their heat range chart.   allis application list
295 specs w/link to heat range cgart
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 1:38am
NGK. B6S
Edited by PaulB - 28 Feb 2018 at 1:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 6:59am
Steve, I have tried several plugs all were 3/8" reach and worked fine(some better than others). I am finally catching up on my winter projects and a valve job on the CA was in line. I noticed when I pulled the head that the 3/8" reach plug is not visible in the combustion chamber at all. Looking at it, there are no clearance issues with valves or the piston. I am far from an expert on this issue, it just doesn't seem to me that the short plugs would be as efficient as a longer reach plug that makes it to the chamber. I remember putting short plugs in my old jeep because that's all I had in a pinch, they ran like crap and fouled out very quickly. I can't post pictures on here from my phone but would be glad to share some if anybody would like them texted. I know many do not like champion plugs on here but I also tried them with good results. Paul-- thank you, I will try the NGK B6. Thank you all
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 7:44am
Into the combustion chamber?  I usually see the thread just flush with the head when the plug is seated all the way. The electrode may extend a little into the chamber, but the threads should always be flush.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 8:19am
Doug, That is what I expexted to see, threads flush/or near to the inside of the chamber. I do not know the thread depth on B/C's or if there is a veriance in head castings on the CA, just going by what I see here on this head.
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 9:57am
hmmm...  we're igniting a gas cloud here.
I wonder which would be more efficient - an explosion started in the center or one that starts on one edge and ripples through.
of course we are talking about a fraction of a second, here...
pretty sure I can predict which would be more destructive to the spark plug.
just thinking out loud here - anybody know of any testing in this area?
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 10:37am
It does not explode, drobCA.  It burns. I'd say the difference between an explosion and a rapid burning it that with an explosion the entire amount ignites simultaneously. With a burn the burn starts at the plug and rapidly moves away, igniting the mix as the flame travels.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 11:28am
A source of ignition within an vapour that will burn results in an EXPLOSION.
A source of ignition at the surface of a liquid that will burn results in a FIRE, not an explosion.
Gary
