d15 power steering leak, internal? |
Post Reply ![]() |
trevorno ![]() Bronze Level ![]() ![]() Joined: 05 Sep 2017 Location: Cheney WA Points: 22 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Feb 2018 at 2:12pm |
As it says, I have a d15 that leaks ps fluid. I've added fluid a lot lately but it always reverts back to 'manual steering mode'. I cant find where its leaking on the ground, is there a way it could be leaking internally? Where should I start looking?
Edited by trevorno - 26 Feb 2018 at 3:16pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22106 |
It's either leaking on the ground or the engine is waaay overfull on oil. Never seen one leak into the engine, so you're on your own.
Can it leak into the engine?
Or are you implying i may be accidentally overfilling the engine? I'm not, but I dont mind the question.
Jim Hancock ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Hi Trevorno.
When was the last time that you checked your engine oil dipstick? Like Doc, I haven't heard of power steering fluid leaking into the engine. |
How blessed we are by HIS GRACE!
I checked it two days ago. It was a little overfull. I just fixed a stuck carb float so I think it's gas that's causing it to be too full. I need to change the oil anyway.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7528 |
Look under the front of the tractor to see any fresh oil leaking. Clean up any dirty areas first if need be. Doubtful that it would leak into the engine. Also check the lines, some might be loose.
*DougW ![]() Bronze Level ![]() ![]() Joined: 11 Jun 2017 Location: Lancaster PA. Points: 75 |
Is it a narrow front and leaking into the pedastal??????
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
When you go to fill it up next time, use brake fluid. If it's just o-rings that's gotten hard the brake fluid will soften them and there's a good chance they'll soften up and swell and stop leaking. Try dropping an o-ring into some brake fluid and watch it swell up over a few days time.
No, wide front end.
Post Reply ![]() |
