175 hydraulic pressure |
Post Reply ![]() |
Josh in Pa ![]() Bronze Level ![]() Joined: 22 Aug 2014 Location: s.e. Pa Points: 47 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Feb 2018 at 2:34pm |
How much hydraulic pressure does a 175 have? I want to run a rake and Tedder That take 2100 psi.
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
Not sure on 175 but on a 170.. The remotes have a rated maximum output of 10 GPM and 2250 - 2350 PSI @ 1800 rpm to them.
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
GPM is your biggest concern. MACK
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22101 |
If you don't have a hydraulic oil cooler ahead of the radiator, cooling may also be a problem after about 30 to 60 minutes on a hot day.
Both are pto driven. I just need the hydraulics to pick them up.
Post Reply ![]() |
