New Idea Wagon Project
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: New Idea Wagon Project
    Posted: 21 Feb 2018 at 9:37pm
I bought this 3 axle New Idea Wagon Gear from Don Bradley and have fixed the minor mechanical issues and have started with the wood decking.  The gear had a hoist on it so I was lucky to find 2 nos brackets for the 3rd axle and a nos spindle for the right one that was functional but had seen better days and a few other miscellaneous bushings, etc. from Albert at Ziegler's.  I was even able to find 2 older Goodyear tires to match the other 4.  Thus far i have installed the 4" x 6" x 16'runners and the 4" x 6" cross braces on 4' centers.  In the last picture are the 9 3" x 4" x 8' stringers that will be on 2' centers. Next will be the 1 3/4" x 8" x 16' planks.  All the edge boards will be 2" thick to keep stuff from bouncing off.  All the wood has had 3 coats of linseed oil.  I know I overbuilt it, but I only plan to do it once.  I plan to take it and my other wagon, the middle picture to a couple of shows this summer.
Edited by Michael Crowe - 21 Feb 2018 at 9:44pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 10:12pm
I'm happy to see you fixing her up right just like I knew you'd do it. Good Job!! This is not the run of the mill gear like most of them out there, if you see this N.I. wagon at a show take the time to look it and his AC wagon too.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2018 at 3:07am
Were these wagons just used to haul bigger loads, or were they a specialty wagon?
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2018 at 6:35am
Mikey you didn't overbuild,,,,,,,,,,,,,,,,,,, you bilt it survivable if you wanna do whattever,,,,,,,,,,,,,,, like hauling a D-8 around the block......
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2018 at 6:59am
In our area they used them on silage boxes
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2018 at 7:38am
Michael, great job on the wood frame. I love these older running gears. I couldn't remember your gear model number, so I did a search & found your earlier post.
http://www.allischalmers.com/forum/wtb-new-idea-wagon-gear-stancion_topic144705.html
This page was generated in 0.079 seconds.
