Painting questions
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: Painting questions
    Posted: 20 Feb 2018 at 8:59pm
The only experience I have in painting is rattle cans, so I know nothing. I bought a spray gun and what I thought was high quality paints. I got the paints at Napa. I told them I wanted the best they had to offer, I didn't care what it cost. The primers are Acme brand. My first question is, what does an etching primer supposed to do? Does it do what the name suggest? It sounds to me like it's supposed to etch into the metal and create a strong bond. Something for the other paints to stick to. The first thing I painted with this stuff was the aluminum name plates. After they dried I wiped them down with acetone, and the primer came right off easily. I could have wiped them completely naked again in a couple of minutes if I wanted. Now those parts were very smooth/slick aluminum, so I thought the other parts would do better. I painted some bare metal and some painted metal that I had sanded and got the same results. On the painted parts, I could wipe the primer off with the acetone, but the paint underneath wouldn't come off. I thought maybe the high fill primer would do better, but no, it wipes right off too.
Second question is the high fill primer seems to not be drying. The instruction sheet they printed for me said it would be ready to sand in 30 minutes. The directions on the bucket said 1 to 2 hours. Its been half a day and it still don't feel dry enough to me. I'm just learning, so maybe I mixed it wrong. I followed the instructions, but it seemed really thin and fogged up a lot. I may use less reducer next time.
The paint I haven't tried yet. I wondered if I even should. If it wipes off I may box it all back up and take it back. The brand they sold me is Martin Senour. They said it was really top notch stuff. I don't know paints, but they say it's all in the preparation. If that's true, and I have to do more than what I done to these few parts, I will never get an entire tractor painted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 9:42pm
Martin Senour should be pretty decent paint. Look on the can and see if it is an acrylic enamel or alklyn enamel.. The acrylic should use a hardener to make it dry faster... The primer will just be "enamel primer" but should dry in an hour if its not really humid. Normally there are different "reducers" depending on the outside temp.  If your using a 50 degree reducer on a 90 degree day, or vise versa, you will have drying problems.  Aluminum is hard to paint, that's probably why they gave you an etching primer. The metal should be VERY CLEAN to start with. What are you wiping it down with PRIOR to paint......... did they recommend the acetone wipe down of primer ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 10:39pm
No Steve, the guy at Napa didn't actually tell me to clean the parts with the acetone before painting. He just said I could use it for cleaning (the gun and such). The acetone is also used for the reducer for the high fill primer. The etching primer uses a different reducer and dried in 30 minutes. The instructions just say clean thoroughly with solvent, it doesn't say what solvent. I just assumed the acetone would do fine. I cleaned the name plates and removed all the old paint with Mother's aluminum polish. It took a long time and I had them real slick and shinny. I figured I needed to remove that slickness, so that's why I washed them with the acetone. The instructions said to wipe down metal down with solvent before applying a second coat. That is what I was doing when I discovered the primer would wipe right off. Perhaps the primer needs to cure longer. That's what I'm doing now, I'm going to wait a couple days and see what it does.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 6:10am
Drying and cureing are two different things, acetone sounds too strong for wipe down to me specially since they said to use it for gun cleaning.   All the paint layers from primer to top coat have to work together as a system, the guy behind the counter selling you the stuff needs to know exactly what to use. I have painted many tractors and have used several brands of paint but always buy only when I feel the guy behind the counter knows his business and have him walk me thru all the steps . If you arent sure go back to the seller and have them explain steps again as it's all too expesive to be experimenting on your own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 6:25am
There is a product called 'gun wash'. Yeah for cleaning the gun out when you're done for the day. It's a 'cut' version of acetone, 'low power', 'watered down'. guy next door uses it and paper towels for 'wiping down before painting'.
All I know is every job he does you NEVER know where the booboo was...
Any of the primer etchers probably contain phosphoric acid to 'etch' the metal surface. Aluminum is 'tricky' to paint as it's soft and the valleys fill in with the mtn material so it's not rough for the paint to bond too. Also needs to be super clean.
The guy next door will use gunwash and paper towel and make ONE pass, then grab  ANOTHER paper towel with gun wash and make the 2nd pass. IF nothing comes off, it's clean, ready to paint, if not(usually the case) a 3rd towel/gw is used.
This kid(50ish) KNOWS what he's doing, should be in a real restoration shop($$$).
One big thing is be SURE the metal is ALL at 'room temperature' . Check with a $20 IR gun ! If the piece has warm+cold areas...paint will NOT bond properly.
I do know 90% of the work to a quality job is prep, 9% paint skill and 1% luck.
The 1% is hoping that multilegged creepy crawlies don't come 'visiting'
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 6:54am
If you wipe fresh paint with acetone it WILL wipe off. You don't want to do that. You can clean with it before, but not after.
I used NAPA Martin Senior paint. Each product has it own special reducer, not just, "Use acetone" You can look all the products up on their site. They have detailed instructions and what products to use together.
NAPA has a "cleaner" you can use to clean the bare metal with.
Etching primer is used on bare metal.
You're gun shouldn't "Fog" you need to turn down your air pressure. Get a piece of large cardboard. Use it to practice a couple strays and set your spray pattern each time before you touch the metal.
Don't worry, lookup the instructions and follow the guys advice on here and you'll be fine. I never painter before and I did it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 6:55am
If acetone is used to remove paint from your gun when cleaning WHY would you use it to wipe down fresh paint on your tractor?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 7:14am
You will find if you let it sit there for a period of 50 years that it will not be any easier to wipe off than the original primer.  Also follow the mixing sheet for the paint and primer to the letter so no guessing on a little of this or a little of that.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 7:42am
YES! A little silly but I actually bought a good stainless set of measuring cups and measuring spoons. Worked good, but a little messy. Something like 1C paint, 1/2C reducer, 2T of hardner. I can't remember now. That's been almost 8 years ago! wow
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 8:07am
Get a paint stick so that you measure your paint, thinner and anything else that goes in the paint. Be very careful with your measurements. wipe/sand off everything you've put on so far. When you get it ready, start with your sealer (thin coat). Depending on the brand be ready to start with the high build primer per the instructions. Depending on how rough your metal is, put on several coats if needed. Once you get as much as you need on the tractor or parts, let it dry for a while, then take a rattle can of black lacquer, stand back about 18" and spray real fast leaving little black fly specks behind. Don't try to paint it black because all you're wanting is a guide coat for sanding. Using a sanding pad, sand your primer with a light hand trying not to leave finger marks. Sand back and forth in one direction only (not crossways). Sand until all the little fly specks are gone. You may find you will need to use some primer filler to fill some minute scratches or low spots you've missed. Practice on an old door or something so you can get the spray patterns,how fast to go, and how much to put on and how wet to spray it. As far as cleaning your gun goes, get a gallon of the hottest lacquer thinner and put your gun parts in it and let soak for only a little while if it hasn't been drying very long. Wipe and blow dry. You can let the high build primer dry for a long time if you want to, but the longer you let it dry (several days) it just gets tougher to sand. Not a bad thing but is hard on the old elbows. If I've confused you or created more questions feel free to PM me.    LEON
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 9:16pm
Well my paintings troubles continue. My problem is the fill primer will not dry. Its been over 24 hours now, so I don't believe it's going to dry. It's not sticky or tacky, its just kind of soft and gummy feeling, not solid. I tried sanding it, I can make scratches in it, but it won't make any dust while sanding. It just gums up the sandpaper. The only thing I know to do is try another reducer. The instruction sheet only calls for two. One for below 85 deg. and one for above 85 deg. I'm using the one for below. It was probably in the 80s when I painted, but I can't believe it would make that much difference after 24 hrs. The mixing ratio is one part primer, one part reducer (50/50), that's pretty simple. So I don't know what went wrong. I'm going to try to strip these parts back down this weekend and start over. I don't think I need to put any paint on them the way they are.
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 10:27pm
I had that same problem once with not drying. I called the manufacturer and they said I got it on too thick and the paint was skinning over. They told me to take a rag with Naptha on it and quickly run over the paint and it would allow the air back in. It worked great. Try that. Also YouTube videos and practice on cardboard setting up your gun. Eastwood has some great videos on YouTube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 10:31pm
Believe it or not Harbor Freight has some really good HVLP paint guns. I know some body shop guys who even use them some. There are some good YouTube videos on setting them up also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 10:35pm
Make sure you've got plenty of air line to give your air time to cool down so the water will separate. Get a oil and water separator And air filter. Remember High Volume Low Pressure. If your using a top load gun. Harbor Freight is another good place to find that stuff as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2018 at 3:01am
HF guns are OK. You want a dedicated gun for primers because primers are very hard on a gun and you don't want to ruin your good gun.  I bought my son a Sata (not sure of spelling) and there is a difference between a high dollar gun and a cheaper one. But, he paints restorations and I paint old trucks and tractors. How warm was it in the shop when you painted? If it's not warm enough in the shop, or they gave you a reducer for warmer temps. you're drying time will take a lot longer, thus messing up the chemical reaction time of the hardener and it will evaporate not leaving enough behind to finish hardening the paint. Do some research on the paint you're using and see if you find more info. on it. I have heard that the paint you are using is vastly improved over what it was a few years ago. The HVLP guns help a lot also. Oh, and it's not a sin to color sand and buff. Just apply an extra coat to sand off. If you get your drying problem solved you can color sand and buff in a couple of hours. Don't wait a day or there will go the old elbows. I agree with the. others, I don't think your paint guy was very knowledgeable. And do get you a paint measuring stick. It's made of aluminum. Wipe it clean each time you use it and it'll last for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 12:13pm
I think I may have solved my drying problem. I called the customer service number on the paint bucket. Come to find out the high build primer I'm using doesn't use a reducer at all, it uses a hardener. Unfortunately, I will have to strip my parts. The customer rep said they will never dry. I don't know a thing about painting, but I knew something wasn't right. I was sold the wrong product, go figure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 1:20pm
Rance I'd get that customer reps. name and I'd use that to leverage the people who sold the paint to me. I don't think you will have to raise a real big stink to get them to fix the problem with no charge to you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 1:35pm
That's why I always looked up the instructions online also. Not everyone at the paint counter knows what they're doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 2:51pm
NAPA would not be the place I would ever consider buying high quality paint and paint supplies.  I know the dedicated auto paint supply stores are sometimes hard to find nearby but it's sometimes what you have to do to make sure you are dealing with folks that know their product.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 7:33pm
I use PPG paint sold by one of the sponsors on this site. What a difference in the quality of a paint job when your finished. Sprays very well with a HPVL paint gun from Harbor Freight. Mix 8:1:1...paint hardner,reducer. I used the 50 degree reducer since it was winter time, even with a heated room. The etching primer soaks into the metal, rust protection and a good base for primer, then paint. $90/gal if i remember correctly.
I have used the Napa brand before on my dad’B-208 lawn tractor. Although it did a good job, the PPG covered better and was much easier to apply. I will not use Valspar products again. They fade badly within a few years.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 6:20am
I use PPG paint sold by one of the sponsors on this site...
If you don't mind me asking, who is the sponsor that sells PPG paint?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 6:57am
You really need to use a paint that takes a clear coat. You can virtually eliminate color fade.
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 3:09pm
AMAC services inc
Merlin Boshart, 319-656-3235
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 4:11pm
Thank you!!!
...and your 190XT looks great!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 8:29pm
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 8:33pm
I striped, re-sanded, and repainted my parts with the etch primer. I also painted some sample parts with the high fill primer with the proper hardener in it. The new instructions said it would 90 minutes to dry, and it took every bit of it. It dried to a hard slick enamel like finish. It looked more like enamel paint than primer. I've used enamel primer in a spray can before and I don't particularly like it as well. It just doesn't seem like the paint would stick to it as well. This primer does seem to sand well, and it looks more like regular primer after sanding, but it still feels hard and slick. Perhaps this is a good thing. It seems like it might be pretty durable. I just wonder if any of you all like the enamel type primer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 9:26pm
your going to notice a BIG difference between primer and paint in a pressure gun compared to a rattle can. As you said, the filler primer WITH HARDENER can have a shine to the finish.. That's the hardener and its OK... you should run some fine paper over it to get a somewhat dull finish prior to painting... also the sandpaper will take out any dust / specs/ bugs/ bubbles prior to the final paint... good idea to finish sand just a little..
Like you said, it takes some practice... ALL PAINTS ARE DIFFERENT... you need to follow directions or get a GOOD salesman to explain to you what YOUR paint needs. I use to go to the local body shops that were painting cars and buy a gallon from them with hardener / primer and get good info.
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 1:47pm
i didn't read all the posts above but , if you don't have one already get a good respirator while messing with these paints and primers!
