7060 Turbo
ABDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ABDave Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Turbo
    Posted: 16 Feb 2018 at 11:09pm
The turbo on my 7060 needs replacing. The wear in the shaft looks like it was starved of oil. The tractor is used to pull a 6 cubic yard scraper once in a while and a round baler at haying time. Other than that it collects dust.
I realize the engine would suffer a power loss if I run it naturally aspirated, but what might some of the other issues be?
Would the inter-cooler need to be removed?
'till later
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote ABDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 11:15pm
I should have said the tractor will be used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 11:21pm
If you think you're going to operate that engine without a turbo?? Leave it in the shed and throw away the keys.  You will slowly destroy that engine without proper air to it. End of story. Park it if you're not gonna fix it.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 5:07am
Some of the sponsors of this forum have new (replacement) turbo in the ~$400 (or less) range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:11am
A turbo is a pretty inexpensive repair on a tractor.   MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:36am
Especially on a tractor that size!  You have not priced new rear tires lately, have you?  You wouldn't get half a tire for the cost of a turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 10:17am
I see a lot of scraper tractor turbo's that fail. They fail because the engines have been stalled too many times at full load. There's no oiling of the turbo when it is at full speed.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 7:41pm
Contact Val or Von Leefers at Area Diesel Service in Carlinville, IL. or Des Moines, IA.  They repair turbos every working day.
This page was generated in 0.223 seconds.
