160 Clutch Shim Question
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Topic: 160 Clutch Shim Question
    Posted: 12 Feb 2018 at 8:58am
I recently had my clutch rebuilt for my One-Sixty and I have a question about the shims.
My tractor is a an "early" model which the service manual indicates should have 3 shims between the stop plate and the crown ring (marked as Position 1 in the photo below).  This should total 18 shims to cover the 6 bolts.
The clutch came with six shims and paperwork that states the following:
"Flywheel Step = 0.175"
"0.060 shim must be installed between flywheel and pressure plate cover"
I think "between the flywheel and pressure plate cover" describes Position 2 in the photo.
My question is do I need to put the shims in Position 1, Position 2, or Both.
I'm going to call the company that did the clutch and see what they have to say also.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 9:57am
Question answered.  The paper that came with the clutch should have had a diagram on it with a very helpful picture indicating the shims are intended to go in the same location as described in the service manual.  The company directed me to a digital version of the instruction sheet that included the helpful picture.
Edited by Flyer - 12 Feb 2018 at 9:59am
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 11:24am
Yes...it should have (3) shims between the cover assembly and the flywheel as the manual indicates for proper release. Rick
This page was generated in 0.219 seconds.
