Help Identifying Older AllisChalmers Tractor
lesliejmorris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lesliejmorris Quote  Post ReplyReply Direct Link To This Post Topic: Help Identifying Older AllisChalmers Tractor
    Posted: 06 Feb 2018 at 3:21pm
We inherited this tractor when we purchased a piece of property. We are assuming it was purchases in the early 60's when the owner built the house.  It runs, has a gas engine, but there is no identifying marks on the tractor.  I can see where there once might have been a plate.  I am attaching pictures and a lubrication and service chart old owner used.  It runs fine, had a tractor knowledgeable friend move it three times for us last fall, but am interested in moving it on, but I have not idea how to market it!  Would love to ID model and year if possible. Thank you.  images can be seen here:  http://lesliemorrisphotography.com/-/lesliemorrisphotography/gallery.asp?cat=201280&pID=1&row=15
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 3:25pm
the curved shifter says late '53 wd or a wd45 which ran up to early 57.  the serial # is on the rear axle housing to the left of the cover in the center on the back.  that will tell for sure.
Edited by CAL(KS) - 06 Feb 2018 at 3:27pm
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 4:04pm
Give your location. Might have somebody close by that'd make a deal on it.
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 5:26pm
Does it have a plate bolted on the right side of the engine?  WD has one, WD45 does not although not a positive ID as motors do get changed around for one reason or another.  Left side, below the Lt brake access panel on the axel housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lesliejmorris Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 5:36pm
It used to as I can see where it was but its gone, with some Gymnastics hanging upside down I was able to find the serial number hidden under the 3 - point brackets and found WD 151215 on the differential cover I am confused as the serial numbers for the last WD's built in 1953 is 13_____ then in 1953 they began building WD45.  Could this still be a 45 with that serial number?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 5:52pm
I’m wondering....how come in the manual photo, “12. Radiator” is pointing to the gas tank?
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 5:56pm
SN WD151215 indicates it is a 1953 WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 6:16pm
Haha yea that's something ha creston
Edited by Mikez - 06 Feb 2018 at 6:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote lesliejmorris Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 6:18pm
I just posted that because it was the only documentation the owner left about the tractor, but I now know it is a WD45 Serial Number 151215 built in 1953 and has a gas engine.  I am going to find it a home.  I will update my location so if anyone is interested in my area they can contact me.
I am in Elk Grove, California, will try to find out how to update my location information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lesliejmorris Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2018 at 6:19pm
Got it, thanks - WD45 Serial Number 151215 1953 Gas engine.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2018 at 6:54am
make sure ya get your coffee cup before ya move it...lolLOL. wd45 great machines.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2018 at 8:49pm
Funny.......
I have three different WD-45 manuals.....one of them misidentifies the gas filler as the radiator just like in his photo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2018 at 11:12pm
What's the form number Brian.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 12:58am
Good looking machine.  Very little rust and the sheet metal looks really straight.  Could be a very tempting project for somebody.  Or just use it as is.  Sadly, way too far from me, but only 40 miles from my mother in law.   Good luck with the sale.
