D-17 3pt Conversion help
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: D-17 3pt Conversion help
    Posted: 04 Feb 2018 at 10:02am
City kid bought 40 acres close by me and a D-17 series I.  I've known him since he was toddler, now he has a wife, two kids and trying to survive on a youth pastors salary.  Told him I wasn't much help on this modern stuff but we'll eventually figure it out.  He bought this 3pt conversion kit and has too many parts leftover.  The part with the arrow point to it I thought went on top of the drawbar between the snap coupler and drawbar clamp but if you use the front bolt of the clamp it appears the clamp won't tighten to prevent the drawbar from moving.  Are you supposed to drill 2 holes in the drawbar and where?  Also the piece circled I assume are for anti-sway chains as it has a 5/16 hole drilled in them but where does this mount?  And last, the small piece at the bottom I never saw unless that unless that is a top link adaptor of which it's already on.  Sorry for the blurry picture but you can blame Tony's Tractor for that, I stole it from his website.
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 12:14pm
JW  go to www.steinertractor.com  ; d17   acso14  they have the instruction sheet for installing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 7:10pm
Thanks Dave, at first I thought you misspelled the word, "also," but figured  it out finally.  Like I said, danged newfangled equipment.
CaseyCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2018 at 11:35am
If it's working, maybe he's just a darn fine mechanic.LOL
D17 Series III,D17 Series IV, 185
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2018 at 2:59pm
The piece with the arrow pointing at it goes on top of the drawbar, it uses the hole from the drawbar strap on one side and you need to drill a hole for the other side. The sway block piece goes over the top of the drawbar hanger and bolts to it with the holes you mentioned. You may need to drill holes in the hanger for these. The small clip piece is part of the top link attachment which is used on the kit for a wd/wd45. I think the series I and II uses the same kit as the wd/wd45 with the top link piece being the only difference.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
This page was generated in 0.232 seconds.
