7020 heater control
Blustery Knoll Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Topic: 7020 heater control
    Posted: 24 Jan 2018 at 9:20pm
My 7020 blows lukewarm air out of the heater. And the temperature control knob is stuck. I pulled the cab roof off, and it looks like there's supposed to be a cable hooked up to the little gear wheel. No sign of it though.
Where's the actual location of the control valve? It seems like it is likely stuck part way open.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 10:18pm
On the right hand side (seated) of the heater core, there should be a 90 deg. fitting with a metal plate on the end of it.  there should be a little lever that should have a cable attached to it, that would run over to the heater knob.  Lot of "shoulds" Shocked  There may also be a valve up around the engine somewhere.  The heater valve that should be hooked up, was notorious for not shutting off completely, thus making the AC nearly ineffective, so check for another valve in the lines, (farmer added)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 11:15pm
I just see two rubber hoses connected to the heater core that go down into the cab pillar.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 6:51am
No valve up there? Then there must be a farmer added one down near the engine.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 2:02pm
Guess I need to start looking around. Where do the heater hoses connect to the engine?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 6:17pm
Thermostat housing and water pump usually..
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 8:04am
Hy-Capacity, AP Air, tractor joes sell the control valve.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 12:11pm
One other place to look is to check that a hose is not pinched shut behind the battery tray. It happened to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2018 at 7:23pm
I can't find a pinched hose or valve anywhere. With my IR thermometer, I get 140° out of the thermostat housing, and under 100° on the return hose to the water pump with the fan on full speed. This was just with the tractor idling on a 25° day.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2018 at 7:02am
You won't get good heat up in the cab running tractor running at idle. Not enough push to get coolant up that far. Get yourself a new valve at the control in the cab or install shut off valves correctly at engine so you can shut it off in summer.
Wink
I am a Russian Bot
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2018 at 5:41pm
I found on the 5/8 heater hose. A 3/4 Pex ball valve fits real tight in the hose. Then use regular hose clamps. I took the handle off and put it in the tool box.  Tim
