Anything
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Anything
    Posted: 08 Jan 2018 at 8:32pm
Is there any parts that are not sold by any of the usual sources or parts you would like to see a better quality of. The reason I ask it I'm looking for parts I could reproduce and sell as I am not able to get a normal day job. Thanks for any ideas?
theropod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theropod Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:28am
Do a Google search for gas tanks for a B. All sorts of other sheet metal parts are out there, but a new gas tank for a B is not to be found. Even finding a used tank is a trick. Of course building the dies to stamp form the two halves would cost a small fortune. Injection/blow molding still would require forms/dies. Fiberglass could be done if after the two halves are joined a sealing liner was employed as ethanol mixed gas will cause leaks. The kicker is after all the work is done just to make a reliable tank you might sell 6 a year.
Put the bunny back in the box!
1938 B, 1977 Yanmar YM2200
No private messages:
use email:
theropod AT yahoo DOT com
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:54am
snap coupler back blade  extensions and pivot blocks.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:42am
Snap coupler latches for a CA
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:49am
Tall order, to find enough of a market for reproducing parts to support yourself, by the sounds of it, that's what you want by the statement of finding a day job.  You could move here, we are hiring.
What equipment do you have, and what are your talents or specialties?  Seems you could start a repair and light machining or welding business and be "somewhere" closer to what you're looking for.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:12am
Hydraulic parts! Controls, valves, seals, rebuild kits, etc. All the parts sites are extremely limited on the hydraulic parts they carry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:40am
What hydraulic parts in specific?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:42am
Power shift valve for 8000 series I am told
Wink
I am a Russian Bot
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:18am
Gearing might be a good option. I see a lot of people on here looking for and having a hard time finding them. I'm sure other makes have the same problems.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 10:28am
just about anything for a 5020 expecially front differantal parts for the 4x4 models!!Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 10:41am
Oh my.  Not a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 12:32pm
I'm not familiar with the blades. Do you have pictures of the pieces
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 1:46pm
Drawbars.  Manufacture or refurbish drawbars for the earlier stuff, pre- three point hitch.  Every antique tractor I've bought had a buggered up drawbar.  Cracks, bends, bad welds, and ovaled out holes.  Find old ones or the ones your customers send you and make'em right.  Straighten, weld, fill, grind , and machine as needed. Then sand blast, powder coat and ship to the customer.
You might be surprised what some folks will give for a factory fresh B or CA drawbar?  To increase production you could also service other tractor brands as well as AC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:11pm
Here is a pic of the pivot blocks and the pic of my front axel pivot bracket I repaired mine but other have looked for a new part. hope this helps the bolts are 5/8 and 2" apart the big pivot hole is 2 3/4" can't  help on blade extensions. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:27pm
OEM quality, D15 and all series of D17 Fenders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:42pm
Are the bolts tapped into the block or all the way through?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:49pm
What would people be willing to pay for these blocks do you think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:50pm
Bolts are tapped into the block about 1 3/4" the block is about 1"x 3 1/2 x5"
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 2:54pm
I'm in need of a couple of those blade pivot blocks. The bolt holes are tapped. I have two blocks with snapped off bolts in them that I couldn't dig out. So I have a blade in pieces because I need replacement blocks. It's on one of my many "to-do" lists.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 4:30pm
Does anybody in central mn have one of these blades or could send me more exact measurements of them? It looks like the back block has a flat piece attached for the angle adjustment correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:30pm
I  cut mine off and welded it back on the new one not that hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 8:51pm
Could somebody get me more precise measurements? I drafted it up as you described and the bolts go into the center hole
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 6:52am
You ever consider doing stuff for the Industrial B's?  That stuff might bring you some cash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 9:23am
Like what?
