190XT intercooler?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 190XT intercooler?
    Posted: 03 Jan 2018 at 7:52pm
Many of you know I own a 1968 190XT. My curiosity has me wondering if anyone has put a intercooler on a factory 190XT, not a puller? The 7020 had one, basically the same 301ci engine. It’s pretty tight in the filter compartment and not sure one would fit without some modification. What benefits can be realized besides obvious hp gains? Would it run cooler? Burn less fuel? Just asking, be interesting to hear responses.
Thanks
Robbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:53pm
Forgot to load the picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 10:48pm
it will add more load to the cooling system.if radiator is marginal,you will be overheating engine.more power than they already have ain't gonna do good things to the rearend.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 5:27am
Must be Shooting for 200 HP!
Thumbs Up
Charlie
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 6:48am
I put one on mine over a decade ago. Doesn't really effect the cooling temp by much.
Edited by grinder220 - 04 Jan 2018 at 6:49am
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 6:52am
It would run more efficiently and you could turn the pump down a tad and not have to worry about running too much HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 6:58am
If it is plumbed properly (that is the key) for the coolant flow, it will run hot on a 90 degree day under full load. Running a corn dryer in 30 degree temps wouldn't be an issue.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 7:06am
Hey Grinder220, do you still run that dryer or is this an old picture?  What size is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 7:15am
This is the first year for it on the dryer. Its plumbed just as it was on the 7020. Only work it does on a 90 degree day is hay work. Some spring tillage and planting is about all I use it for anymore .
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 7:16am
500 bushel and thats from this past fall. Usually have a G705 moline running it.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 8:11am
Thanks
Robbie
I would not even think about changing a thing on that gem of a 190.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 8:36am
Yeah, I thought it looked fatter than mine.  Mine is 350 Bu.  I'm just glad I'm not the only one still using something like that, lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 12:24pm
yeah I'm one of the few left running one around here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 5:43pm
Thanks Grinder220 for the info. I was curious if this had been done. I am not sure I will try it, I was just curious if it helped fuel efficiency and what other advantages that you feel you gained? What type of intercooler did you use? The XT is easy on fuel in my opinion but always thinking of upgrades if they are effective and make a already great tractor even better.
Charlie as my little brother, I may not have out pulled you this summer due to my rear tires, but power is something I have plenty of. I bet I can spank yours on a dyno! Lol. My pulling days are over, she proved her power this summer, farming is all she will do from now on.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 6:27pm
AC720Man, I appreciate the picture of your 190, but my pet peeve is an oil filter that is BLASTED with PO#2. Sorry, just my opinion. The rest of machine looks AWESOME!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 6:47pm
More power yes,better fuel economy I can't say for sure. Its always been a very fuel efficient tractor and I've never really noticed any difference. It's off a 7020 and if you ever do put one on you'll want all the lines that the 7020 uses and the spacer for the oil fill. Also need to grind the front part of the cooler down slightly to clear the alternators hot wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 6:49pm
in 150 hours or so that filter will be gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 7:33pm
Would you be willing to share where you got the seat? Dad retro-fitted a bobcat seat on the original frame somehow 12 years ago and it is starting to fail miserably, LOL!!
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 7:43pm
AC720man I don't have any advice for you on the intercooler, but damm that tractor is beautiful!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 5:42am
Rob you know you love rolling the coal at the track!
Edited by Charlie175 - 05 Jan 2018 at 5:45am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 7:19am
The picture was taken as soon as I finished the tractor. Just couldn’t resist a quick picture in front of mom/dad’s barn while on a test run. All filters were replaced shortly after the return home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 7:25am
The seat frame is origional. 3 piece seat cushions came from Ricks AC tractor parts. He is a member on the forum. He sells top quality parts. These have the metal backing as opposed to plastic or wood of other company’s. Thanks everyone for the nice comments. I am pretty proud of her. He also sells the bushing kit for the frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 9:18am
Charlie that black and white picture looks like it was taken in the 70’s....i like it. Nice touch with the vintage camera mode.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 9:26am
XT's at just under 100 hp with stock turbo ran 12-14 psi intake pressure max  - the 7020 with the smaller .58 A/R ratio exhaust housing on a TO4B80 and the extra fuel ran over 20 PSI.
The difference in intake air temp was  double or more ... you engineers can figure the exact #   T= p/(r R)  ha...
at 10% over stock fuel setting, as stated, the cooling system was maxed out if the radiator was perfect - the addition of a 6 blade fan as was supplied by aftermarket add on AC systems will keep one at about the same temp... or it did on my XT  on a dyno test at 100 hp...  the down side is worn pulleys will result in short belt life as the extra hp required by the fan is an increased load on the belt. (note - the 7000 series had different # of blades on the fan for ROPS vs Cab w/ air - putting one of these on a 210 -220 with the double A fan belts results in same problem)   Also keep in mind the intercooler was not designed to increase hp - it was to keep the engine life  the same at a higher hp setting.  The intercooler will only add hp IF there is more fuel being introduced into the combustion chamber that could be burnt w/o the intercooler..  adding an intercooler w/o adding the cooling needed  to handle the intercooler will result in shorter engine life when the optimum coolant and oil temp is exceeded.  It is the same for adding a turbo as to hp on natural aspirated diesel engines.
Edited by tbran - 06 Jan 2018 at 9:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 4:28pm
THAT OIL FILTER LOOKS AWESOME AGAINST THAT PO2 ENGINE!!!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 7:44am
The difference in intake air temp was  double or more ... you engineers can figure the exact #   T= p/(<font face="Math1">r <font face="Times New Roman,Times">R<font face="Math1">)  ha...
TBran thanks for all your information. I've read how Turbo compressor can heat up intake air sometimes 4-5 times. I remember reading on here about how farmers in the southern USA would fabricate additional intercooler plumbing beyond it to aid cooling in higher temperature regions. Sounds like the 7020 could have benefitted from additional plumbing no matter where it was operating.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 8:55am
As per the Service Manual on a 7060, the turbo can heat the air up to 350 to 400 degrees at 15 psi boost pressure. The intercooler core tries to bring that temp down by passing  180 degree coolant thru it. Tractor pullers use ice water and hope to bring air temps down to 40 degrees intake air at the intake valves. Imagine how hot that air would be when the boost is 100 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 1:41pm
DrAllis, yes that is so true. Ever mistakenly touch a shop air compressor's tank fill pipe that routes from it's piston cylinder(s) to it's air tank? When running, that pipe is seriously HOT. Makes me think that AC should have built the 7020 with an exhaust manifold pyrometer sensor mounted before turbo with it's temp gauge mounted into the operators cab dash. I have a pyrometer in my truck's cummins exhaust and try to keep it below 1200 degrees when trailering a heavy load.
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 3:29pm
Are the pulling guys running 100 psi ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 4:16pm
I assume there is nothing "stock" as far as parts in the head/valve train in that type of application?
