Gleaner F2, series 3 flex head?
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F2, series 3 flex head?
    Posted: 01 Jan 2018 at 6:10pm
Just wondering if the series 3 flex head will mount up ok on a f2? I know it will need some wiring since it is hydraulic drive reel. Also I know the header height wont work but I don't have that for my current header and get along just fine.
Currently running a rough floating head with the pit man drive.. broke the driveshaft in the fall and sickles are pretty dull. Have been keeping my eye out for another head but there isn't really that many around, so might end up fixing the old one up.
Just wanted to know if anyone has upgraded to the series 3 on a F2..
 My M2 has a 315 flex that is hillbilly wired by that previous owner but couldn't get the reel speed to change, so I have some electrical work to do I guess.
All the best for 2018
Nick
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 6:29pm
Series 3 heads hook up the same way as the older models.  Some years ago, I remember our local AGCO dealer sold a kit for getting the hydraulic reel to work on older models.
It is very hard to find good used heads.  Everyone wants series 3 heads, so that drives up the prices, even for junky ones.  I would be tempted to do a major rebuild on the one you already have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 6:51pm
Yeah I was pretty sure a series 3 would fit. Just wanted to check for sure
I am really thinking about fixing up that floating cutter bar head. Worked fine for me and probably wouldn't cost too much too fix up nicely. Previous owner put poly under it,  would have to put in new sickles/ replace the driveshaft. put some new tines etc. probably paint the wood bats while I'm at it. The m2 worked great with the 315 flex so will use that as my main machine. But that header also needs work too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 10:14pm
Move up to a JD head for your F2. A big improvement on a Gleaner.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 7:57am
What would I need to be able to use a JD flex? Haven't seen many bish adapters around.. I agree it would be nice though, and there is still quite a few jd heads
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:07am
I made my own adapter but I'm sure one of the company makes one.
made mine with hydraulic tilt.      MACK
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 9:14am
Mack, would u mind telling us what gleaner u have & what # green flex head u put on it, Thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 10:19pm
F2 combine. 216 JD head.
200 series JD head is 6 inches shorter than Gleaner or 900 series. First head was 215, too short for 6- 30" rows.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 10:35pm
 does "shorter" mean narrower? My 15ft Gleaner F2 w/wobble box fits 6-30's nicely
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 5:56am
Yep a Deere head is narrower than a Gleaner. A 15 won't fit 6-30 and a 20 won't fit 8-30.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:25am
Would a 520 gleaner head fit 8-30 rows, Thanks Dave
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:30am
Yes it does real nice. It is what I run
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:33am
Thanks for the info, Was it difficult to build the adapter?  Me and dad are pretty handy with steel/metal fabrication so could probably build something.
How does the F2 hand the 16 foot? good rasp bars in it probably
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:56am
Works good. Have hard skip tooth bars. We don't raise 80 bu beans here.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 11:38am
Nick,  I have wide space bars and F2 is happy at 3.5mph in 60bu beans cutting 6-30's.You can go faster but settings need to b spot on for that.
