8000 AC cost |
Mikez
Topic: 8000 AC costPosted: 21 Dec 2017 at 3:13pm |
Hi all. What would be the worst case cost on getting AC working on 8010. I would assume that would be the compressor expansion tank and What else is big dollars in there. Just wondering. Was gana go look at a tractor and wanted to have price in mind. Thanks
Edited by Mikez - 21 Dec 2017 at 3:14pm |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Posted: 21 Dec 2017 at 3:20pm |
My L2 needed a new compressor, drier, expansion valve and since I didn't have time I hired it done = ~ $1,200. That was 3 years ago.
Wink I am a Russian Bot |
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 21 Dec 2017 at 3:22pm |
Who is doing the work? You or a shop?
Parts and refrigerant alone could run well over a grand IF you have to replace everything. You did say worst case right.......now it is unlikely you will need to change your condenser, somewhat unlikely that you would need to change the evaporator, but entirely likely you may need to change the compressor, and consumables. Best guess knowing nothing more than that, between 100 and 500 in parts you buy aftermarket.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
Mikez
Posted: 21 Dec 2017 at 3:37pm |
Yea would just be parts cost. We will do the wrenching. Thanks
LB0442
Posted: 21 Dec 2017 at 10:46pm |
Here is a picture of a 7060 that I put redid the A/C system in about 10 to 15 years ago. I used an HR6 compressor instead of the old A6 unit. I cut new brackets for it to weld on the old compressor mount plate, I think I used just 1/4 steel plate. Used the same A/C belt and location. The lines all hook up the same. I had a hose shop make up new lines and replaced the dryer. Flushed out the evaporator and condenser with brake clean. I never had to touch the system again, sold it a few years ago.
![]() Here is a link to the style of compressor I used. |
LB0442
Posted: 21 Dec 2017 at 10:56pm |
I just put that compressor number into rock auto and it was only $232 there. Thats a pretty good price for a new, not reman, unit.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3603 |
Posted: 22 Dec 2017 at 7:37am |
Try AP Air Inc. About 5 years ago I installed their A6 replacement kit for 134a in my 7060 & it's still running cold. Here's a link to the AC 8010 parts
https://www.apairinc.com/shopping/?model=11378 |
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 22 Dec 2017 at 7:49am |
How much commonality is there to the AC components between 7000 and 8000 series tractors?
fourthgeneration
Posted: 06 Jan 2018 at 3:00pm |
I just bought all the components (nothing is being reused) for a AC 7020. I think it was $1350 for lines, evaporator, condenser, compressor, dryer, sanden kit and switches.
DrAllis
Posted: 06 Jan 2018 at 4:23pm |
Commonality of parts between 7000 and 8000 series ?? maybe the compressor and that's about it. Everything else is different.
AC7060IL
Posted: 07 Jan 2018 at 7:31am |
MikeZ, have you redone your 8010's AC yet? If so, which route did you decide?
Mikez
Posted: 07 Jan 2018 at 8:00am |
Nope, the weather went down hill. We didn't make it to go look at the tractor. Thanks for all of your input, if they still have tractor and we go ill have a good idea on price to offer. Thanks
