Rebuild kits
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: Rebuild kits
    Posted: 19 Dec 2017 at 2:22pm
Was wondering where people have a good luck with rebuild kits have a D17 engine that I’m rebuilding and need a kit for every place I have found doesn’t tell the compression ratio the pistons have been made too
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 2:35pm
AGCO dealer has always been where I've gone.
Wink
I am a Russian Bot
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 3:00pm
If you get a Reliance/Powermax kit they list their compression ratios. I know from checks I did, that the D17 kit is the correct 7.25 ratio
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 6:31pm
Last i checked agco didnt have any kits left. But that was a couple years ago. They need to see orders placed before making a new batch. I believe power max was making the kits for them. Go ahead and try to order a kit for a 175 tractor(same engine but higher compression).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 6:34pm
And dont confuse an agco kit with a different kit that the agco dealer tries to sell you. They will try to sell you a reliance kit if the agco ones are not availiable. You would be paying them to be the middle man. If going reliance get it from a seller on here.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:41pm
I have had a couple of engines rebuilt with Reliance kits, no problems so far!
