AC 7020 Running Hot Exhaust
Blustery Knoll Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Topic: AC 7020 Running Hot Exhaust
    Posted: 04 Dec 2017 at 10:29pm
I bought a 7020 this fall, and have gradually been trying to get the bugs worked out of it.  I've gone through the things I knew needed work when I bought it. Now, I am finding things that I didn't expect.
I have noticed that it blows a lot of black smoke, even under moderate load. Last night I hooked it up to a small chisel plow and after about 10 minutes, I noticed that had an orange glow about 8-10 inches out the top of the muffler. When I stopped and got out, I noticed that the exhaust manifold and turbo had an orange glow to them. I left it on high idle and got an IR thermometer from the garage. After running it under load for a few minutes, I would get temp readings around 950 degrees most places, with a few of the hottest spots being in excess of the 999 of the thermometer's max readout.
FWIW, I could hold rated engine speed in 4th gear HI, but had to run in 3rd gear LO to keep the temps to what I noted above. This resulted in no flame out the top of the muffler. I am sure I ran it at a higher temp for the 10 minutes or so before I stopped to check things out. Temperature gauge never moved past normal operating temperature. I did let it idle at least 10 minutes after a 5 minute drive back to the yard. This morning I noticed that the exhaust port to the #5 & 6 cylinders has cracked off from the rest of the manifold. So, something is obviously in need of remedy. Is what should I look for, or did someone just turn up the fuel too much? It did previously have a leaky gasket for the front exhaust port. I found the bolts loose, and tightened them, but that didn't totally stop it. That was on my plan of things to replace during winter down time, as it didn't seem to be too big of a deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 10:50pm
doesn't sound hot to me. Pyro on my 8070 reads 1050 on most working loads.301's seem to like to crack ex manifolds. Might check timing.Retarded will heat.
Edited by SteveM C/IL - 04 Dec 2017 at 10:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 11:00pm
Should it smoke like a super stock puller though? Maybe not quite that much, but it's a lot of smoke, even pulling a 13' disk running 4" deep in corn stalks.
Will retarded timing also make for hard cold starting? It's gotta be plugged in below 45 degrees or it will NOT start. Doesn't like to start  below 20 degrees, even if it's been plugged in all day. Maybe I just need a bigger block heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 11:18pm
should not smoke that much.Turned up and run hard probably hasn't helped the rings any.Hows the blowby?Can't speak to retarded timing for hard starting.Diesels usually have a method of retarding timing some for better starting.Too much probably would work against you.MACK,Doc or Ed needs to speak to that,not me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 12:04am
It slobbers a bit of oil out of the breather, but the but I've run stuff for years with worse blowby for sure.
Could a leaking exhaust gasket let out enough pressure to reduce boost pressure, and thereby lead to an overfuel situation? I am thinking I should put on a new manifold and install a pyromometer and boost gauge to see what is going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 7:15am
Retarded timing will make it start better, but can cause more heat. I would say pump is turned up which will cause hard starting. Extra fuel dumped into cylinder will cool cylinder temperature, causing hard starting. Pull shut off knob out until you see smoke may help starting.
Most any motor running loaded will turn manifold red at night. Exhaust temp over 1200 degrees is getting close to max temperature.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 8:13am
Some facts about a 7020 tractor. #1. They are kind of known for breaking exhaust manifolds (over time that is). I blame it on two things.....the big heavy muffler and probably higher exhaust temps due to the 123 PTO HP.   #2. They are quite famous for having manifold bolts working loose. Again, I blame that on the same two things, You'd be wise to install new AGCO manifold bolts when installing a new manifold. They are a SPECIAL bolt, so don't buy anything but the AGCO bolts. I advise checking bolt torque every engine oil change to keep them tight.   #3. 7020's normally do smoke like a Mack truck when throttling up and when the engine hits about 1800 RPM, the turbo spools up and the heavy smoke goes away. This is NORMAL....get over it.   #4. Maximum exhaust temps are around 1250 to 1300 degrees as per the Service Manual. If the injection pump has been "turned-up", just shift down a gear and less HP will be produced by the engine. A 30 psi gauge tapped into the intake manifold will indicate actual turbo boost. A 7020 would be around 20 psi full load on a 70 degree day. More boost will show in cold weather.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 8:26am
Well I'll try again. Dang putor had to throw a hissy so took a while to get it to boot back up. What others have said can apply, but it sounds like someone has been fiddling with the pump, but someone like Injed knows more about that. One thing you did that probably saved your motor was to idle it for a while before you shut it down, which let the motor normalize. You already know you have to do some exhaust work, so do that first and see if anything improves. Check all you pressures, timing, etc. and set everything bone stock and test it in the field again. If everything straightens up, then you can start tweeking it for more power if you need it. If you go flying at it blind you'll spend a lot of money and still not know what your problem is. Take a good look at your air filters and see if they're dirty or obstructed or even a rag somewhere in the intake. I would also put a close eye on the turbo. Someone may have put the wrong one on and it's running way low on boost. That's why I like all the gauges you can get and you can tell the problem through them. The turbo may be failing also causing a loss of boost also. Excessive black smoke means there is a lot of unburned fuel going out the stack and that's a waste. Hope you find it, and let us know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 8:55am
Thanks guys for all the information. A couple more questions.
How hard is it to check the timing, and undo "turning up" the pump.
It smokes black at all rpm. I don't notice it lessening until the load lightens. There's visible, but not really thick smoke at full speed cruising down the road with no load.
One other thing, the tach reads 2700 rpm at WOT, is the tach that inaccurate, or has the governor been messed with.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 9:31am
those tach's aren't known for their great accuracy, especially with worn pulleys. If it smokes heavy black all the time, there is a problem. As Dr pointed out, a boost gauge can be a great learning tool. Does it seem to have a boat load of power, or is it a dog? Those were also known to lose an intake manifold plug, thus losing a lot of the boost, an exh plug could also have similar effect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 9:38am
It seems to have plenty of power, but factory spec is 75% more than my previous largest tractor. I would probably feel like it not sluggish at 100 hp.
It's definitely pretty sluggish at low rpm, which I just figured is the nature of a motor with a turbo.
farmboycitygirl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 10:21am
I had a 7020 and it did everything you are talking about in the post - it would black smoke when pulling, not as bad as my 190 xt smokes Tongue - the exhaust manifold bolts were always coming loose, once even blew the exhaust manifold gasket between oil changes.  My 7020 was always hard to start when cold, if I wanted to use it I always plugged it in for a couple of hours before use.  Not very helpful but my 2 cents Smile
