Allis model #8 loader fit a D14?
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: Allis model #8 loader fit a D14?
    Posted: 21 Nov 2017 at 4:09pm
Hi All-
Just wondering if a Model #8 loader will fit a D14?
Thanks,
Troy
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 8:13am
I might be wrong, but I don't think it will fit.  I had a #8 loader for my CA.  Below is a picture of the CA.  You can see the loader mounting brackets attach through the fender to the main frame supports of the platform.  I suppose it's possible to fabricate something to attach the mounting brackets back to the axle on a D-14 but I'm not sure if the geometry would work well.  Also, a  CA is most likely a little narrower than a D-14.  Good luck if you try it!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 4:08pm
I think Brian is right.
I think a CA bucket is 36" wide and a D-14 is 42" wide, so the boom for a CA would be narrower than a boom for a D-14.
Gary
This page was generated in 0.178 seconds.
