Hitch Size
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Hitch Size
    Posted: 20 Nov 2017 at 9:09pm
I have a Wd45 and I'm going to pull a trailer in our local christmas parade.Only problem is that my trailer has a 2 5/16" ball and the drawbar has a 3/4" hole and I can't find a 2 5/16" ball with a 3/4" shank. Have any of you had this problem and what have you done or what would you do.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:20pm
We drilled out the draw bars and old wagon hitches to a 1" hole. Got tired of picking up a hitch pin only to find out it was to large.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:22pm
This isn't the first time it's happened to me is it hard to drill out the hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:26pm
Bolt a plate to Drawbars with a hole just behind Drawbars big enough for your hitch ball.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:29pm
That's what I was thinking about doing so is would work with all of my trailers with big hitch pins also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:40pm
Thanks for the quick reply's here is a picture of my Wd45.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:48pm
nice
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 10:17pm
Both my Wd45s have 1" draw bar holes. One came that way. The other was worn so much that it took a few minutes with a die grinder to finish rounding it out s I could put a hitch ball on it. Even my C had a 1" hole in the SAE extension. No reason you couldnt dril it to 1". When you buy a convert a ball make sure you get the 1" shank one the 3/4" shank one can't except a 2 5/16" ball. I have trailers with all three size hitches and you can't beat the convert a ball for convenience.
Edited by Dakota Dave - 20 Nov 2017 at 10:21pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 4:03am
Nice looking WD-45.
You need to check the Power Shift rear wheel eccentrics.
Hard to tell in the picture - but it appears they are not turned all the way to the 'locked' position.
Gary
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 6:33am
If you have a 3pt then buy or build a 3pt receiver. Then you can pull 1 7/8, 2, 2 5/16, pin on, or pintle. Very handy piece
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 6:41am
Torch the hitch off the trailer and weld am implement style clevis hitch.   Ball hitches have to be the dumbest idea ever. Hate them!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 7:01am
I bought a couple of these 8" long , 2" receivers for $8 each. They're designed to accept any 2" sleeve/ball combo.
I welded one onto my 'carryall' for my D-14s as I never,ever use the orignal drawbars. I have several sleeve/ball combos as well as  a 'blank '. That I use as a drawbar.
The other I welded into a 'slide on' adapter that I slide onto the left fork of my A-C forklift. It normally has a 2" ball in it. GREAT for moving trailers around here, well, once you get the hang of the 'offset' of the trailer from forklift center !
A 'drawbar' version of my forklift receiver would be easy to make, bolt on and  IDEAL for pulling that 'free trailer' outta the bush.....Sometimes simple tools make life easy , well easier....
I'd get a piece of C-channel that slide-fits over the drawbar, bore hole to attach, weld a spacer bar on top( to clear bolt head), then weld 8" receiver to that. Dang I could have made one in the time it took me to type all this....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 7:40am
Like Gary says, your eccentrics are NOT locked down.  That puts TOO much stress on the lock and you will probably shear it off.
Like Jay I put a 2" receiver on the drawbar of my WD45 only I just bolted it to the drawbar rather than weld it.  Bought it at Harbor Freight.  Also bought the 3-ball insert from there also.  Got a H-F near you?  If not, sign up for their emails and you will get a flyer with coupons once or twice a month.  The receiver and the 3-ball hitch go on sale quite often and the shipping is only $5 for EVERYTHING that comes in that box.  I've gotta put one on my CA now too.  Works GREAT,,,,,,, HTH
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 9:17am
Naw, them eccentrics are fine! Wink
If you ever need a replacement I have 8 for sale, plus two centers if one should get messed up!  Big smile
When you tighten them, start with the one that is at the lowest.then the next two lowest and then the top one.  At least that's how I did mine and they seem to work fine!  I have a 1/2" breaker bar that is about 2 1/2' long,  works great.
Edited by john(MI) - 21 Nov 2017 at 9:22am
1terrygladys View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1terrygladys Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 10:01am
Nice tractor.  I notice you've got a chain hook on your front end.  Is it welded there, or how is it attached?  I've been wanting to put something on my tractors to be able to pull them, without scratching up the paint.
WD-45, WD, Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 12:09pm
It’s just welded to the frame rail
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 12:24pm
We welded together a rectangle shaft to slip over the drawbar with the correct size hole in top plate hanging back from the end of the drawbar for the ball to fit in and holes to allow the drawbar pin to go through on the top and bottom of the shaft.  Simply pull the pin when I want to remove or slide the shaft onto the drawbar and drop the pin to install and use the ball.  This is like Mack suggests, but without having to bolt the plate on.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 1:01pm
This setup and combination of receivers works great on my 190XP, WD 35/45, and the 'G'. It only takes a few moments to switch from one to the other. The front mount, on the WD, has to be switched to the G by moving the bolt-on backer plate. Inexpensive to make and flexible. Sorry if the sizing is too big. Ross
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 1:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 2:43pm
Ross D. I like your setup and I might have to build that in the future but I think for now we’re going to cut the shank off of a 2 5/16” ball and weld a bolt on that will fit the drawbar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 3:20pm
Thanks for mentioning the eccentrics they were not locked. Could any damage have happened?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 8:10pm
Not much damage could have happened I don't think.  But like I said, it puts TOO much stress on the lock and you will probably shear it off.  Could also swing back and forth and the eccentrics could get really stuck on the rails.  I've never seen it happen, but a rail could break off.
WORST thing is the sway of the tires COULD THROW YOU OFF the tractor and under it.  That HAS HAPPENED.
It's a good practice to once a year take the eccentrics loose and move the rims and then put them back again, starting at the bottom and work toward the top.  That way when you really HAVE to move them, it's pretty easy.  Otherwise they WILL rust in place!!  I KNOW!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 8:17pm
That makes sense when I drive it in road gear last weekend it had a pretty bad sway to it but that’s the first time I’ve drove it in road gear that far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 11:12pm
I second what Ted said about bolting a receiver to the drawbar . Buy an inexpensive one and drill holes to match the ones in the drawbar . I did one and it works well for pulling trailers around .
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 9:47am
Love that adapter, will be building one of those this winter.
