Wd45 clutch
Rick143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 clutch
    Posted: 20 Nov 2017 at 12:25pm
How hard is it to replace the clutch in a wd45? I have been noticing it slipping when I take off in high gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 12:42pm
Remove hood and then radiator. Pull steering shaft up and out. Pull hand crank shaft forward. Remove the engine from chassis.  Are you sure it isn't the hand clutch slipping ??
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 5:10pm
Hand clutch is much easier to check and adjust before having to yank the engine, does the hand clutch lever stay back and have a nice click when thrown forward?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 7:05pm
Would the hand clutch slip when releasing the foot clutch but the hand clutch is locked back in the driving position
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 9:34pm
Yes, if it is bad enough. (A chain is only as strong as it's weakest link).       MACK
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 10:34pm
may haft to take some shims out' will help;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 6:08am
Is there an easy way to determine which clutch is causing it
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 6:43am
Put it on a dyno.  If the PTO slips under load, it's the foot clutch.
AaronSEIA
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 6:54am
Pull the battery box and remove the cover over the hand clutch and measure the gap.  This is much easier than replacing the foot clutch just to find out you chose wrong.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 12:11pm
Am I to measure the gap with the clutch released or applied?
