Hydraulic Speed
tsid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tsid Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Speed
    Posted: 20 Nov 2017 at 11:22am
I will start with this...Not a mechanic, do my best, but I run the tractor. Have an AC 7040, put a bale processor on it (vermeer bp 9000). I cannot get enough power in my hydraulics to run it. At full throttle 3000 rpm, it is barley getting the job done. I know there has to be something that I can adjust to speed this up. PLEASE HELP.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 11:31am
There should be a small rod below the seat that will allow you to adjust the flow of the remote valve.  It only adjusts one so you may have to reach behind the valves and twist the control that way from the outside.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
tsid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tsid Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 11:33am
Thank you! I will start there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:19pm
Are you saying the hydraulics don't run the hydraulic motor fast enough, or not enough pressure to move the hydraulic cylinders?   MACK
tsid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tsid Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 9:25am
Well, its both. The motor on the feeder is not turning fast enough, along with the cylinders not moving fast enough.
