WD-45 rear wheel parts
russt66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 rear wheel parts
    Posted: 19 Nov 2017 at 9:01am
I recently acquired a WD-45 AC. With a little work I got the thing running. Problem is after I got it rolling I could hear a squeak / grind. After inspection the bearing cap on the rear right wheel is gone and the bearings are junk. I located all of the part numbers in another post on this forum, thank you. I can't find anyone selling that cover. I wanted to order all of these parts before I started. Suggestions?
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 11:13am
Would have a used one available  Ia 563 357-2615
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 11:56am
Thanks, I found some on eBay. Now to the task of replacing the bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 5:42pm
I have replaced some of these bearings on WD's, inner and outer races. Had some puller discs built then used all thread to move the races.
Some pictures on here somewhere too.
Edited by Sugarmaker - 19 Nov 2017 at 5:44pm
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 5:58pm
What kind of squeak/grind? This different from the typical clicking/scraping sound you can hear from the rear end as you rock a tractor back and forth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 7:02pm
Cap is gone, I can see a race with no bearings. It screeches like a bad bearing. The tire wiggled when you engage the clutch.
