180 gasser
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: 180 gasser
    Posted: 16 Nov 2017 at 9:06pm
This past harvest, it has become obvious that the 180 is is in need of a major tune up after auger duty and before planting. Planning on AC/Delco plugs, but are their any recommendations for wires,cap and rotor?? Scared to even think of getting new points(heard horror stories). Does the coil last forever or go ahead and change it out? Not looking to go the electronic ignition upgrade yet. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 9:22pm
Go with a electronic ingestion. Points and condenser are absolute junk today.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 9:48pm
With an electronic ignition system, is the ceramic block gizzmo bypassed?
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2017 at 5:14am
Did our D17 IV and I think the ceramic resistor is bypassed. But the wiring diagram that is part of the package will clarify. I agree, go electronic. We bought points some time ago and they were junk as Mack stated. The points did not align (and I bought them from a vendor on this site, though most other items I bought from them were of good quality).
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2017 at 5:20am
You wouldn't want a 6 volt coil with EI anyway. The resistor is for 6 volt coils on a 12 volt system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2017 at 6:12am
Our tractor IS 12 volt and has a 3" long by 3/4" block with wires (1) in and (1) out
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2017 at 6:16am
Reread your post Doug with my glasses on(LOL) ,I see what your saying about the coil and resistor ,thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2017 at 6:50am
Had problems with electronic ignition I put in so got a good set of points and condensor from Steve NJ (www.bb-customcircuits.com/) and it runs better than ever. I kept the Flamethrower coil I put on with the ei. Did not buy the Pertronix electronic ignition from Steve but wish I had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2017 at 6:53am
The old resistor was to drop voltage across the points, reduce the damage from arcing and would not be needed for a electronic ign.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2017 at 1:56pm
I just did the entire line except for wires on a D17.  I got the parts at a real auto parts store.  fires right off and runs nice.
This page was generated in 0.215 seconds.
