2300 disc help
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: 2300 disc help
    Posted: 14 Nov 2017 at 3:51pm
Looking at a 13' 2300 disc
Needs a bearing for sure, he says the others are good all blades look good
Any opinions or rough value estimate
All info is greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 4:09pm
The bearings are still available. And the spools are to.
I bought one maybe five years ago for I think $6 or $700. It needed more then I thought. The rear sets still had original paint but the fronts were bad. Both gang bolts were bent, I put ad in old allis and scored one NOS and one used, then I bought new bearings and blades, it had been used all loose so some of the spools were wore bad as well as the center spacers, I think only needed two spools. I took and picked out the best spacers and only replaced the worst ones, like one or two on each side. The one side I took and cut down blades to use as backing plates and the side I got the used gang bolt he sent me some with it. Now inside the spacers between bearings there's a square tube that the blades go on. I just went to iron shop and got what fit the gang bolt and inside blade. Think I covered what I did, and now I have a good sound set of discs, sorry was long winded
Edited by Mikez - 14 Nov 2017 at 4:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 8:44pm
Did it turn out to be a good disc for ya
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 9:49pm
Yea they work good
Tim (Cent.WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 9:06am
I bought a pretty nice 15' last year for $750.00 needed one blade, I diced over 150 acres with it and it worked great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2017 at 9:07am
On another note I saw a smaller one, I think it was a 13' go for somewhere around $1300.00 this fall at an auction. The smaller ones usually go a bit higher.
