180 Allis weight |
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Topic: 180 Allis weightPosted: 07 Nov 2017 at 4:13am |
Does anyone know what a 180 weighs, tires are loaded and has a Rowe Foundry weight on each rear wheel? Don’t need an exact weight just close
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 07 Nov 2017 at 6:27am |
Per 'Tractor Data' website: 6420 to 10,270 lb. http://www.tractordata.com/farm-tractors/000/1/8/181-allis-chalmers-180.html |
SteveMaskey(MO)
Posted: 07 Nov 2017 at 6:32am |
Thanks Gary, looks like I need a trailer with at least 2 7,000# axles
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3132 |
Depending on what size tires, about 9500-10000
DougS
Posted: 07 Nov 2017 at 7:23am |
Trailer with a GVWR of at least 10,000 pounds. With this rating it would have brakes. Don't pull it with too much truck or you'll be treading in CDL territory.
Allis dave
Posted: 07 Nov 2017 at 7:37am |
According to a local DOT officer, You don't need to worry about a CDL with a pickup truck weighting over 26,000#'s unless you're hauling commercially. I asked the question because I pull a 20,000$ gooseneck with a 3/4 ton truck.
I'd say you're right on with a 14,000 trailer. I'd like that better than a 10,000.
SteveMaskey(MO)
Posted: 07 Nov 2017 at 7:48am |
I have a CDL but I do not haul commercially. I have a 40 acre and a 60 acre plot bout 14 miles apart. I wanted to haul instead of drive. The tractor has 18.4 X 28 tires
DougG
Posted: 07 Nov 2017 at 8:38am |
Average 180 ive been around weigh between 6500-7500 max, maybe back in the day some guys would load them down bad/ heavier , but probably didn't stay together long either
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 07 Nov 2017 at 8:46am |
I'm with Doug here. My 185, 18.4-30's with no weights, tires empty weighs close to that lower number, the weights add 300# each and then it depends how full are the tires.
DrAllis
Posted: 07 Nov 2017 at 8:50am |
Shipping weight was right at 7500 lbs and then you add the fluid, so close to 9,000 with 18.4 x 28's full of juice.
