6V SOLAR battery Maintainer
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Topic: 6V SOLAR battery Maintainer
    Posted: 05 Nov 2017 at 12:21pm
I have found these two items (solar battery maintainer)for my WD(6v, with cutout, in a bldg with no plugin power) to keep the battery in good condition!!!  It  will take awhile to find out how well it works!!!  The first item is the solar panel, must be used with the second item which is the maintainer.   AND from a US company(but made in China!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 12:35pm
Well I can't make the charger unit for the $13 they want, if I bought new parts...the microcontroller and PWM is silly easy for me, done that for 3 decades..sigh, 1/2 my life, great now I'm depressed, thanks......sniff, sniff
I keep buying 'stuff' from www.banggood.com as I can't build for their prices....great deals on all kinds of LEDS, even them old 'Edison' types but with LEDs in them.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 12:44pm
let us know how it works as I have been looking for something.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 12:49pm
I have a couple of 12 volt unit that I have bought from Menards that work good, I just keep moving them around to keep my batteries charged up.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 4:44pm
I've used larger ones for river gauges in my old job. 12 volts, but 6 volts should work equally well with a good 6 volt controller. In Ohio you want to aim it 60 degrees up from horizontal and facing south. It should do a good job.
Edited by DougS - 05 Nov 2017 at 4:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 7:16pm
We've been using solar chargers on our trailers to keep the breakaway Batteries charged up. They work great. I would imagine the 6V version would work just as good...
Steve@B&B
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 2:40pm
got mine from NAPA for 12 or 6 volt charges to full charge and then goes to maintain mode has a digital read out tells you what percentage the battery is charging and tells you it is maintaining
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 12:07pm
I have run this 6V solar battery maintainer for several months now including recent cold weather.  It works quite well, helps my battery problem a lot(search post on 6V WD Pertronix).  It is not a charger, will not charge a dead battery, but adds charge only as needed to maintain a charge, to make up for normal leakage and storage loss while the tractor is parked.  Recommended!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 6:39pm
6 volt panel offn a solar powered fence charger will work too.  Many people throw away the whole fencer, when the battery or connections go bad...Wink
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 6:10am
Could you use a 6v charger from a game feeder? I do have a couple maybe I should try them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 6:22am
yes... though I don't know the specs. A 6v battery is a 6 v battery, a 6v charger is a 6v charger...'generally' speaking.
There is a HUGE difference in 'charger' vs 'maintainer'. A charger WILL recharge a low battery,well should... a maintainer will simply 'top up' a fully charged battery
Jay
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 7:14am
Coincidently, I heard a seemingly knowledgeable car mechanic suggesting a solar
charger/maintainer that you set on the dashboard and plug into your car's cigarette lighter socket.
I checked with mine and confirmed that the cigarette lighter goes dead when the ignition is off!
Could be a bit disappointing for anyone who follows that advice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 7:24am
Smile yeah.. 'cigarette' plugs turn off, 'power' plugs MIGHT stay live....
BUT you ALWAYS have to check....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 8:29am
I have a 12 V solar panel. I never leave it on because it puts out 14 V and there is no "maintainer" circuitry. I wish I knew how to rig it so it work as a maintainer. I'm sure it can be done.
 My 12volt maintainer is a real handy thing to have around. I have had several batteries that would have just been replaced a few years ago, and now seem to work fine, once they set on the maintainer for a couple days.
 Last spring I had to take a 6 V battery out of one tractor and bring it with me to the WC to run the 12V maintainer on it for a few days. Maybe I need to find a 6V maintainer
Edited by CTuckerNWIL - 10 Jan 2018 at 8:30am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 8:33am
They do make battery charge controllers for unregulated solar panels.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 8:48am
CT
The easy way is to put a diode in series..from +solar out -->|--- +battery
The diode drops(use up) .6 volt, so...
 14v solar -.6v diode  gives you 13.4 for your battery
Almost any silicon diode will do, say 50V, 1A, or better
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 10:41am
I’ve used a jillion solar charge controllers on remote river gauges. They do an excellent job of regulating charge voltage and the ones I used automatically switched to the float mode. An additional benefit is your circuits are fused. Ever see what a battery with a thousand amps of discharge capacity does when something shorts out? It aint pretty.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 4:21pm
You can get a charge controller pretty cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 9:15pm
A 12 volt starting battery generally needs 14.200 volts for a full charge. Any more leads to overcharging and loss of water from the electrolyte. That is if the battery is at 68F. Warmer or colder the voltage can be a tiny bit higher.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 2:45pm
Some of the above posters want to use 6volt (from a fencer) or 12 volt solar panels which you already have or can get, to make a 6V maintainer cheaply.  Note that when not connected to a load, socalled 6v panels will produce about 7 to 11 volts in full sun and "12volt" panels will produce 15 to 22 volts in full sun.  Connect 2 of the 6v solar panels in series (+panel---------+panel-) to make one 12v panel. The maintainer below will not work with only one 6v panel.
Get this 6V battery maintainer:
and this cable with clamps to connect it to the battery:
Plug them together, cut off the plug from the maintainer leaving as much wire as possible, about 2 inches, connect, using your own wire, direct to the solar panel, not to a solar controller.  Put the solar panel in a good sunny location, prefer south side of bldg, tilted down about 30 degrees from horizontal.  Connect positive (check panel with a meter to find which is positive) wire from solar to the red wire of maintainer, negative to black. Connect the clamp cable to a 6 volt battery, you are good to go!
For those who wish to connect a 12 volt solar maintainer to a car, get the 12 volt version of the above, and if the cig. lighter has no power when the key is off, you can also get a cig. lighter adapter which will connect to the OBD connector under the dash and  will be live when key is off.
Green led on the maintainer lights up when OK!
CTucker, I live in your area of IL, I will PM you for contact info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 11:10pm
I bought a 12V solar battery charger from HF several years ago. had the chance to use it one day, I left the 180D out in the pasture one day and forgot to turn off the fender mount radio. then discovered it when I went back to it a couple days later! I put the panel on the hood (tarp strapped it on so wind wouldn't slide it off) and hooked it up. no lights or guage to tell if it was working or not. went back a day later and the tractor started good! so now I know that thing works. just slow as the panel isn't very big. dunno if it would work for 6V, but it should, any thing you can put into any battery should work i'd think! it wasn't very expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 3:36am
Just remember that you want a maintainer, not a charger. A charger putting out 7.1 volts will boil the battery, if left on continuously. You want to set it for about 6.75 volts, the typical float voltage. Yes, those few tenths of a volt will matter.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 8:08am
CT
Jay
Many years ago I bought  solar panel, about 12" x 36", to use on our motor home when camping without electric. I found that it was more bother than worth.
But with all the electronics in chassis the engine battery will run down in a few weeks, when not in use. So I put the solar panel in the garage south window, and hooked it to the engine battery, I did add a diode to it. This worked well, kept the battery charged.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 8:21am
Steve@B&B
Getting side tracked a little.
I had a trailed with break away break brakes with 12v battery, looked about like a 6v lantern battery. The brake system worked fine, and the battery never needed charging.
Years later I bought a new 20' trailer trailer with break away brakes.
This new one the battery would run down when not in use. So I now unplug when not in use.
Are all of them that way now ?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2018 at 11:25am
SORRY, My post above has a bad link for the cable!!!
Below are the corrected links for solar cell and cable.
Still working fine!!!
Plug them together, cut off the plug from the maintainer leaving as much wire as possible, about 2 inches, connect, using your own wire, direct to the solarpanel, not to a solar controller.
