190xt Hydraulic Repair Starting Point
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt Hydraulic Repair Starting Point
    Posted: 03 Nov 2017 at 10:39am
I am going to dig into my next problem this weekend. My 3 point arms drop when loaded with 3 point equipment fairly quickly. I was hoping to get some direction on where to start from forum members. It appears that the Hydraulic pump was replaced at some point so I don't think that is my main problem. I believe it is working fine because it will raise the equipment just fine. The problem is that once loaded with equipment, it creeps down fairly quickly. If I hit the control knob, it will raise back up. This makes it difficult to go down the road to the next hay field by constantly hitting the control valve.
So, my question is: do I need to concentrate on my control valve and rebuild it, or do I need to look at the lift cylinders as a starting point? I have a minor leak in the control valve area and I see there is a rebuild o-ring kit available, so it may not hurt to start there. I am just curious if others know of a test that I can run to isolate the problem or if they have had the same problem and know what I should start to fix. If the lift cylinders need rebuilt, then that may be quite expensive. Any thoughts on where to start are appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 11:34am
If you compared ten 190XT's for 3 point hitch settling with a load on them, I'd guess at least 9 of 10 would have some degree of settling. The heavier the load, the more it will settle. The hotter the hydraulic oil, the more it will settle. If the cylinders are the problem, you will see a leak. You could try and replace the 3-point valve with another one (only used...no new available) and still have the same thing. There is one thing you could check on the valve. There is a roll pin driven into a spool to make a handle. Make sure it is rotated tight and seated. Other than that, settling is somewhat normal. That is why the Position control lever is there. Pull clear up on it and the load can't settle down.
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 11:38am
The 3pt valve is leaking past the spool and body. To drive down the road with a load on, use the position control valve to hold the load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 6:29pm
I neglected to state that my position control lever and my traction booster lever will not move up. They are stuck in the lowest position. So, this may all be related. I am guessing the valves are stuck. So I was going to deinstall all valves and check them out. Curious what my next step should be though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 7:21am
You don't need to remove any valve stack to figure out what is wrong with the position control and T Boost linkage. If both levers are stuck, figure out why. It isn't anything with the valves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 7:50am
Thanks for that direction hint. I have a follow up problem to inspecting why the levers are stuck. I tried to remove the aluminum decal cover over the levers to look down into the lever area to see if I could lubricate something and I cannot get the power director knob unscrewed. I hate to tear up the knob with a pair of pliers so was wondering if there are any tricks to removing it?
I have to admit though, the last guy must have tried to fix something related because he ripped up half of the aluminum cover. He didn't rip up the half with the power director though, so I was trying not to do any further damage. I am guessing these aluminum covers are hard to come by.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2017 at 7:28am
The position and depth levers are probably rusted up on the pivot shaft.
Pulling the side cover on the console is what is needed to work on the control levers. Only 4 screws.
It's possible that the position control is out of adjustment
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 9:51am
Thanks for the hints. I pulled off the side cover over the weekend and squirted some WD-40 on the lever flanges. They were very rusty. I worked the traction boost and position control levers back and forth and finally freed them up to the up position. I decided to not take them apart and thoroughly lubricate them since they appear to be working good enough now. Thanks Joe(TX) for the side panel hint. I should have noticed that side panel access, but I followed the tracks of the prior guy and I shouldn't have.
