black 430 corn head question |
Ben (MI)
Joined: 02 Jun 2010 Location: SW Lower MI Points: 770 |
Topic: black 430 corn head questionPosted: 02 Nov 2017 at 6:20am |
I need to replace a couple of the stripper plate adjusting bolts on my 430 black corn head because they are broken off. In looking at the parts diagram I can't figure out how difficult this job will be for myself with only moderate mechanical ability. If anyone has experience with this please share your thoughts. Thanks.
Part time farming with a 1980 7060 and 1984 F3 hydro.
DrAllis
Posted: 02 Nov 2017 at 7:04am |
If you don't have a torch and maybe/probably a welder, don't even start.
Ben (MI)
Posted: 02 Nov 2017 at 7:25am |
Thank you doc, I will get the mechanic to take a look. One row is open way too far causing excessive shelling. I wound up running 3 rows on a couple of acres. Is there a temporary fix to get through 25 more acres?
DrAllis
Posted: 02 Nov 2017 at 7:29am |
Pound it back shut where you want it and tack weld something to hold it there.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Posted: 02 Nov 2017 at 7:30am |
I'd just get it fixed myself. Or you can pick 25 acres with 3 rows. It would not take that long.
Edited by Lonn - 02 Nov 2017 at 7:31am |
Wink I am a Russian Bot |
Ben (MI)
Posted: 02 Nov 2017 at 7:35am |
Thank you guys.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12327 |
Posted: 02 Nov 2017 at 7:51am |
Sounds like you're lucky enough it's one of the outside rows!
Ben (MI)
Posted: 02 Nov 2017 at 8:14am |
It is! I am going to try the pound and tack weld in place trick to finish up. If I fail I will just run 3 rows. Doc says the bolt replacement is a difficult fix.
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 02 Nov 2017 at 7:11pm |
Just out of curiosity (we have the same head),were the broken bolts from wear and tear or "self inflicted" ? I was considering tweeking the plates next summer myself.
Ben (MI)
Posted: 02 Nov 2017 at 7:18pm |
One was broken and I broke the other. I beat the affected plates to where I want them and we'll try running. If they move back out of position too quickly I will get one of my helpers to tack weld it in place, thanks to doc's suggestion. I might try to replace the bolts off season but will likely just add it to the mechanics list.
Edited by Ben (MI) - 02 Nov 2017 at 7:19pm |
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 03 Nov 2017 at 1:40am |
make sure to clean the header off for storage, wet chaff is the #1 reason behind sheared off deck plate bolts.
Get some Kano Kroil and an air hammer with a long slender point before you break any more off. :) I was able to free up an entire 6R30 header that I sold to a guy with just Kroil and the air hammer. Got the deck plates all adjusted up and I guess it worked great. As far as getting broken bolts out, I am thinking you might have to strip the row unit bare and weld a nut to the sheared off bolt, then heat it up with a torch or use Kroil and a air hammer to break it loose. if you are lucky you might be able to get to it from underneath but I doubt it. |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Ben (MI)
Posted: 03 Nov 2017 at 6:07am |
Thanks GM, I will probably leave it for the mechanic but may tear into it and see what damage I can do. Most of the other plates adjust freely but we'll check out the ones that are a little tight before breaking the bolts. I think I do a pretty good job of getting stuff cleaned up before storage but who knows how it was treated the 40 years before I bought it. I'm only a fair mechanic, that is why I have Dodge in my garage, haha!
