Gleaner m2
Ben s View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben s Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner m2
    Posted: 01 Nov 2017 at 8:10am
A friend of mine is selling his father in laws m2 I'm interested in purchasing it what are common things to look for when purchasing one and would this be a good combine to start with I have little experience with combines
Edited by Ben s - 01 Nov 2017 at 8:11am
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 8:50am
Hey Ben,
I recently bought a M2, I'm not an experienced combine operator/ inspector but I usually look over the general condition like wear on augers, check the straw walkers for play in the wood blocks, check grain pan for holes. Most machines bin has rotted out by this point, I check to see how they repaired it, seen everything from tin metal off the side of a barn to spray foam, to a nice professional looking job with galvanized or stainless riveted in place.
Check sprockets to see how they are worn, My F2 has some very sharp sprockets in need of replacing. Is it gear drive or Hydrostat? My M2 is hydro and I haven't used it in the field yet but I already like it. Any heads with it?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 10:37am
See if the leading edge of the cylinder bars are nice and squared off or are rounded. If rounded check to see if they have been reversed. If not been reversed then you have a new wear surface to work with.
Wink
I am a Russian Bot
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 10:43am
As the others have said already. Chains and sprockets and cylinder bars. You can run into big mines if you end up having to replace cylinder bars. We always kick them in gear and do a walk around and look for anything unusual. Also check warning lights. If they all work that’s a good sign. I also like to see working ac.
We have an L2 and it is an excellent machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben s Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 11:02am
Thanks guys I'm not sure if it's gear drive or hydro it comes with a grain head what would it be worth if it's in ok shape?
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 11:36am
In my mind the weakest part is the drive for the walkers,grain pan,and sieves. Over the years the key ways ware on the top beater shaft. Causes the grain pan and sieve to not shack even on both sides,will cause them to break.
Did not watch mine close enough and broke the pan. To check make sure the sprocket on the right side of upper beater shaft is not loose. Also watch the chaffer at low speed and make sure it dose not move side to side,only back and forth.
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 9:28pm
As others have said quality of grain bin repair will give a little insight as to how the rest was cared for. Also check the bottom of the bin on the outside right before it gets to the swivel for the unloading auger. A lot of those are rotted out and ive yet to see a repair that was up to my standards including mine lol check sprocket teeth and make sure their not too sharp. Also see if ground speed, cylinder speed, engine rpm tach is working properly. Those sending units can be pricey. Also check reel speed and see if reel speeds up and slows down.
joepro91 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joepro91 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 2:50pm
Just to add....
I just bought an M2 this fall also.
Many guys have told me that an M2 with a black engine and tan is a more desirable machine then the black interior and orange engines.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 1:43am
Condition is a big factor on a used combine, after that its just desireable options like a hydrostat and the variable speed header drive.
IMO get at least a 78 or up, preferably a 81 or up, with the hydro and you will be doing good.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
