D-17 battery cables at NAPA
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: D-17 battery cables at NAPA
    Posted: 26 Oct 2017 at 9:45pm
The positive battery cable broke on my D-17 Series II.  It was only about 9 years old.  Anyway, I drove to Napa rather than call AGCO this time.  Napa looked at it and said we don't handle one like that, however we can build one just like it.  So, that is what they did from scratch.  Ran about $15 for all the parts.  Seems this was cheaper than the AGCO cable.
Is this the better route on these older tractors?  Thanks in advance for any thoughts.  I did get it installed and the old girl fired right up with no issues.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 9:47pm
Napa has done that for me many times, works good for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 12:19am
EP,
I had some heavy long cables made up by NAPA for my trailer battery down to the winch. Saved me many dollars and got custom lengths. They had the tooling and ends to make a nice neat job of that project.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 3:18am
Is the battery terminal end molded on or did they use those two screw compression terminals  where the cable joins the terminal?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 4:20am
The ends are pressed on by a hydraulic machine
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 7:47am
I buy my supplies from NAPA but put them together myself.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 8:16am
Buy the supplies from Napa and melt the pellets.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 8:29am
Good morning.   Excuse my ignorance on this subject; but, what does "melt the pellets" mean?    Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 8:55am
NAPA will sell you positive or negative battery terminal ends and eyelet ends. I ususally use my vise to hold whatever end I am working on. Strip the insulation on the wire and then drop a solder pellet that you get at NAPA into the terminal. Heat the pellet till it melts and install the stripped cable. After it cools I manually crimp again with the hammer type crimper. Then if you haven't forgotten to slide your heat shrink on seal up the terminal to wire connection. You now have an excellent battery cable.
