OC: 3pt Brush Grapple?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: OC: 3pt Brush Grapple?
    Posted: 25 Oct 2017 at 4:10pm
Hey guys...Dad has a Deere 4720, and I've been thinking about adding a 3rd remote so I can install a brush grapple on the loader. But...that's a super expensive route. $2,100 for the parts and installation. Yikes! Dead
So...being the penny pinching "wanna-be farmer" I am, I thought  about improvising by building a 3pt hitch mounted device. It would be sort of like a carry-all in basic design, but have the grapple piece at the top operated by a hydraulic cylinder, and a hydraulic top link to tip the whole assembly. The tractor has a loader, and I'm wondering (since I just need to move some brush piles every now and then, and not heavy regular use), if I could just unhook the loader hoses (with the loader left on the tractor) and plug in the hoses for the grapple cylinder and hydraulic top link?
I'll be the first to admit, I don't know much about hydraulics.
What do you guys think?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 4:19pm
If you've got a 'free' or 3rd remote available, I'd bodge a grapple on the loader.
easy enough to add a 'set of lower' forks to the bucket, then all you need is a 'bent arm' that the 3rd remote controls.
The set of lower forks could just slide into the bucket, use a chain + hook to 'secure' to bucket. I'd use wood to fab up the grapple BEFORE cutting/welding steel. wood's a LOT easier to use, lighter, cut fast, screws together easy too!
You could do the carry-all-grapple the same way but heck loaders already there and it would be easier to drive !
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 4:22pm
Thanks, Jay. That was my original idea, but see, I don't have a 3rd remote. Installing a 3rd remote is what I got the quote from John Deere for.
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 4:36pm
Take a look at this.  It makes 1 set of outlets into 2 and it is electrically controlled.  There are also manual models.  I did a search for "hydraulic multiplier valve" and got a bunch of different designs.
https://summit-hydraulics.com/product/hydraulic-multiplier-scv-divertersplitter-valve-couplers-switch-box-control/?gclid=EAIaIQobChMI16Gtg9yM1wIVgYd-Ch0CagosEAAYASAAEgLUVfD_BwE
Hope this help.  Certainly a lot cheaper.   Dale
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 4:49pm
That certainly is interesting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 5:37pm
OK.. no 3rd remote...
possible options...
add a 12v winch, use cable to move the grapple. similar to snow blower chute operation.
the grapple doesn't need a lot of holding power, just needs to lightly grab the load as forks carry the bulk of the material.
you could just use a long cable and long arm,like trip buckets have. old school and after 20-30 loads your arm might get tired.....
maybe google 'homemade grapple', images .. to see what comes up...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 5:49pm
Creston, Hydraulics are really not that hard to bodge up.  The electric multiplier valve above is a pretty good value, but likely you could find a 3 spool valve (manual or joystick) from surpluscenter.com, maybe for less.  You need to know if your system is open or closed center, the PSI (pressure) and the flow rate (GPM) for your particular tractor.  Once you have this info, go to surpluscenter.com, and see if any of their valves match up.  They also have an excellent tech help section, if you have questions...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 5:51pm
Thanks guys!
I've been thinking on this, and I got to thinking since the bucket is easily removed/installed, maybe I can make a grapple to mount on the loader, and use the 12v winch like Jay suggested to run the grapple. Like he said, the grapple part will just be holding the load down while the forks support it, for the most part. I don't think I could go a manual route, as the tractor has a cab.
Or...spend a little more and go the splitter route.
Seems like I've got a few options to choose from. I'll think about it and make a decision off what seems to fit my need/budget best.
Edited by CrestonM - 25 Oct 2017 at 5:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 5:53pm
I would put a manual valve / splitter on the bucket DUMP line and run it to the grapple... You would have raise/ lower and grapple open/ close...... when not needed, remove the grapple or bolt it wide open and use the bucket as raise / lower and bucket fill/  dump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 2:00am
look up GNUSE manufacturing in Arlington NE.
CaseyCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 3:21pm
I have been using a hydraulic splitter for years to help with my stump grinder.  Wouldn't want to be without one.  It looks like the pricing may have gotten better since I bought mine, which is good news for you.  The best feature is the momentary switch, which might help you quite a bit on the grapple.
http://www.allischalmers.com/forum/hydraulic-multiplier_topic115167.html
D17 Series III,D17 Series IV, 185
