Tire covers?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Tire covers?
    Posted: 17 Oct 2017 at 6:15pm
Any of you guys that have equipment sitting out...do you ever cover the tires up with something? I've heard it said they make covers for tires that keep the elements and UV rays off, and help prolong tire life. Seems they're some kind of water repellent canvas that fits over the tire. Anybody ever tried that? If it really works, I might try covering the tires on some of my equipment, to help them last longer. Some of my stuff I leave jacked up on blocks, so the pressure if off, but it seems covering them might help as well.
Thanks
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2017 at 6:24pm
When we store something outside we sit it on planks to keep tires off ground. if practical I will tarp the whole machine such as planter. But their are limitations on doing that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2017 at 6:31pm
A lot of RV's use covers to help the tires last longer. If you store the equipment inside out of the sun you shouldn't need them. When you tarp something make sure you have good ventilation under the tarp otherwise the condensation is harder on the equipment than being out in the open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2017 at 7:08pm
Usually we're pretty dry down here, so I don't really see much need for a tarp. I was just thinking something to keep the UV rays from damaging the tires over time.
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2017 at 7:18pm
In my experience, the bottom of the tire in contact with dirt will rot the tire out far before uv rays make cracks on top, you will see little cracks between tread where it was in contact for a period of time. And depends on the tire, these new cheap china trailer tires get cracks very fast.   Imo you keep the tires clean and off the ground it will help a lot.   Seems like dirt sucks the oils out the rubber (thats just my theory). But yes UV will get them eventually.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2017 at 6:48am
Hi Buddy!  Get the tires OFF the SOIL.  Sitting on concrete or wood is OK, as long as they are dry.  Get some inner tubes that are a little bigger than your tires and slit them down the middle on the inside and put them on your tires.  A cheaper method is tarps but they are harder to deal with, especially in the wind.
Edited by Ted J - 19 Oct 2017 at 6:49am
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2017 at 7:31pm
I've seen them on RVs as Hubert said, but never on farm equipment. I don't see why it wouldn't work just as well. I got one JD disc I should sell but I keep thinking I'm going to get back into dirt farming someday. I moved it the other day to mow the weeds down grown up through it, and of coarse the tires were flat. I got an Oliver drill that sits in a shed, although on dirt, and the tires go flat on it as well.
This page was generated in 3.047 seconds.
