ISO E Feeder Beater Slip Clutch
allisguy.11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Topic: ISO E Feeder Beater Slip Clutch
    Posted: 10 Oct 2017 at 6:58pm
I need a Model E feeder beater header drive slip clutch that gets put on the combine for corn. Mounting my E-330 corn head for the first time and I'm excited!
Anyone out there have one they are willing to part with?
Thanks!
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 8:28pm
Do you need the two jaws or more?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 8:30pm
I'm sure I have one, would have to look to be sure.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 9:24am
i need the whole assembly. just bolt her up. sprocket with plate, jaws, pressure ring, 3 springs. shaft size is 1 inch.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 9:32am
Just a FYI there's diff speed sprockets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 10:24am
its only showing one style in the parts book. change the sprocket on the other side to the bigger one. maybe I'm lost but its only showing one.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 10:33am
70544539? is that part of the assy ? I have a NOS with sprockets - the springs and slip clutch is missing but available ... cheap if it will help .. and I wish I could share your enthusiasm... :-)
Call B&G Equipment Paris Tn...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 10:34am
and you should locate a cob shield as well....
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 11:50am
there is not a part number for the complete assembly. Its all individual.the plate with the spocket is 70544514, the clutch jaws are 70568714 and 70536714. the pressure ring that holds the three springs is 70575287. the studs that hold the springs are 70544391
I can come up with the rest
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 11:51am
what do you mean cob sheild
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 1:01pm
I'm sorry, I was thinking about the A Gleaners, the E's just had one sprocket on the drive clutch.Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 1:05pm
It's a shield at rear or raddle to prevent cobs from catching under slats as it flip under to prevent cobs breaking wood slats......if yours has a steel raddle you probably don't need it. I never had one on my A2 and ran whole cobs with no I'll effect that I knew of. Did break a couple slats over time but can't remember if in corn or beans....it was well worn so I put a steel one in from Manchester Mfg.
