road speed, 18.4-38 vs 20.8-38
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: road speed, 18.4-38 vs 20.8-38
    Posted: 04 Oct 2017 at 6:21pm
just wondering if the tire size makes much difference in travel speed? were 18.4-38s factory standard on a 7040 and 20.8 an option?
Thanks
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 7:20pm
According to my Titan/Goodyear Ag Tire Handbook which I downloaded from the Titan ag tire page a couple years ago, the rolling circumference of the 18.4-38 is 207 inches and the 20.8-38 is 215 inches. So the 20.8 will be 3.86% faster than the 18.4 or conversely the 18.4 speed will be 96.3% of the 20.8 speed.
Gerald J.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 3:37am
Traveling speeds change. Also remember that the 20.8s will raise the 7040's drawbar 2-3 inches taller than the 18.4s. This drawbar height change can really play into leveling/setup of certain trailing implements (ie AC1300 field cultivator).
Edited by AC7060IL - 05 Oct 2017 at 3:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 7:10am
thanks Gerald good chart for future reference.
Ac7060IL It is on a tractor i'm going to look at.. current one I own is on 18.4-38, should not make a difference for my equipment accepct might have to adjust hitch on the 2500 model disc.  Thanks for mentioning that though.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 7:12am
Won't it depend a little on what rims you put the tires on too?  I make this statement because of a situation I just ran into.  I have 18.4 38's on my tractor, and never paid much attention to the rims to be honest, as everything was left as I bought it.  One of my rims rotted out and got one from a neighbor who had a junk 7020 with 18.4's on it.  Come to find out, I had 18 inch rims and he had a 16 inch rim.  So now my tractor sits a tad uneven, the tire mounted on the 16 got a little taller than it was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 9:19am
According to the handbook I referenced above, the 18.4-38 preferred rim is 16" but a 15" is acceptable. 18 is too wide but is the rated width for 20.8 -38 tires. The wide rim will make the 18.4 squat.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 9:28am
Yes, now that one of the rims is a 16", it "looks right".
When I get rich, i'll get another 16" for the other side.  Smile
Or I'll get even richer, and get a new 18"rim and 2 new 20.8 tires!!  Yeah, that's it!Wink
This page was generated in 0.262 seconds.
